Question about Linksys Computers & Internet
I have the 5 port switch, and am unable to open the nat setting
BigZ1981
  • 24 Answers
SOURCE: NAT
First, you need to get into the user interface for the router.  To do that, just open your web browser, type in 198.168.1.1 & hit enter.  A login prompt will pop up if you're able to access the router.
If you've never done this before, the username is blank & the password is admin
What, exactly do you want to do with the NAT firewall?
To enable/disable NAT: click on setup, then click on advanced routing.
To filter Internet NAT redirection: click on security, then click on filters.
You can find this information in the User guide provided by LinkSys at:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1166859876500&displaypage=download
Select your version number, then click on User Guide when it comes up.  User guides & Interfaces for the BEFSR41 are almost identical on every version.
Posted on Oct 27, 2007
redhaze89
  • 854 Answers
SOURCE: port setting to allow my xbox to run games
Hello djand2kidz,
Inorder to resolve this we need to open application ports for the Xboxconnection. This problem can be resolve by any of the following:
  1. Opening port Numbers TCP 88, TCP/UDP 3074
  2. Lowering MTU size and Disabling SPI
  3. Enabling UPnP
  4. Enabling DMZ
  5. Upgrading the firmware of the router.
  6. Set NAT filtering to open (Only available on WGR614v6, v7, and v8)
Here are theoptions on how your Xbox connected to the internet. Opening Port Numbers TCP 88, TCP/UDP 3074:
1. Make sure that Xbox has valid IPaddress of the same range of the Netgear router.
2.
Assign static IP address on Xbox.The following values should be used while assigning static IP address on theXbox.
IP Address: 192.168.1.x (e.g. 192.168.1.200)
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
Note: Here ‘x’ can be any uniquenumber from 2 to 254 depending upon the IP address assigned to remainingcomputers in your network.
3. Oncestatic IP address is assigned, the requisite port numbers can be open using thesteps below.
a. Open the browser(Internet Explorer or Netscape) and type the IP address of the Router(192.168.1.1) in the address bar.
b. It will prompt youto Login into the Router (Username = “admin” & Password = “password”).
c. Select "Port Forwarding" under "Advance"
d. Select "Port Forwading" under "Service Type"
e. Click on "Add Custom Service"
f. Prepare the following Service for opening port 88 TCP/UDP.
g. Clcik on "APPLY" after creating Xbox_1
h. Again click on ‘Add Custom service and thenenter the values to open port number TCP/UDP 3074.
i. Click on ‘Apply’ after creating Service Xbox_2.
j. OnceXbox_1 and Xbox_2 services are created you will there entries under ‘PortForwarding/Port Triggering Option.
Posted on Apr 11, 2009
govinda123
  • 2260 Answers
SOURCE: nat problems
You can reduce the MTU settings on the router to 1365.
disable the firewall on the router.
you will also need to open the ports on the router for the X-Box
The port numbers will be 53, 80-88, 3074
Click Here for more info about the networking.
Posted on Oct 12, 2009
SOURCE: how do i change my NAT setting from strict to open
i have the same problem and i cant play COD with any of my friends
Posted on Jan 25, 2010
GetSolved
  • 18 Answers
SOURCE: I am unable to open
Thanks for posting your problem with fixya.
I understood your issue and I would request you to follow the below steps 1. Type in 192.168.2.1 on your web browser. 2. At Router's login page, type your username and password(Default Username: admin Password: (blank) ).[ Contact DLINK customer support for details. Toll free number on products box] 3.Once you are in, browse the different tabs and look for UPnP 4.Save and test your XBL connection.
If no go, I would request you to follow the steps on this link. It would be really helpful for you. http://www.mlgpro.com/forum/showthread.php?t=137247
Great time. I appreciate your feedback.
Posted on Oct 12, 2010
Hello. I am trying to get my NAT open with my linksys BEFSR41 V4.3
You are trying to open the NAT on the router.
For this you will need to reduce the MTU settings on the router
to 1365. Disable the UPnP on the router.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Sep 14, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I want to change my nat type
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
Apr 19, 2010 | Linksys WRT160N Wireless Router
Better online gameplay xbox 360 open nat type
Hey to open your NAT log into your router and look for a setting called DMZ enter your xbox IP (usually starts with 192.168.1.?) into the DMZ box and enable it.
Good Luck & Game on!!! :)
Jan 25, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I'm trying to open my NAT for an Xbox 360.
I think you want the NAT open for X-box.
For this you need to open the router set up page.
Is there any computer connected to the router .
If not then you will need to connect the computer to the router.
Reduce the MTU settings to 1365
open the ports for the router.
Nov 27, 2009 | Port Designs Cradlepoint Technology...
My router nat settings are set to strict how do I set them to open
you will need to change some settings on the router.
reduce the MTU if the MTU settings on the router is 1500 then change1365.
Also you will need to open some ports on the router.
Click here for more info
Nov 21, 2009 | Computers & Internet
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
Change NAT to open
Go to portforward.com and then set your xbox to conenct using the DMZ option on your router.
Jan 20, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
My NAT setting is to strict to play xbox live.
You'll just need to open the port number for the specific game that doesn't play. Click the link below for the port number of your game. Use port forwarding feature of the zyxel when opening the game port.
Click HERE
Nov 22, 2008 | Zyxel Prestige 660HW Wireless Router...
Ps3 is on nat setting 3 strict
You need to forward a port for gaming. Call Sony and ask them what port should you open. Or go to www.portforward.com if you wanna know what port would you like to open
May 15, 2008 | Computers & Internet
Strict NAT?
If you call microsoft, and tell them that your NAT is strict, they will tell you specific ports you will need to forward. (For Free). If you arent sure how to forward ports, call up your routers manuafturer, or send me another message. I have forwarded my ports as well.
Apr 20, 2008 | Belkin Wireless-N Wireless Router with...
Computers & Internet Logo
23 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
