Question about Cameras
It keeps coming up on my screen protected card.and i cant take a picture or delete a picture.what is wrong?
  • Obertelli
    Obertelli Oct 01, 2010
    Please state the make and model.
  • ciarakerriga Oct 01, 2010
    Fujifilm Finepix A170
    Brigadier General:
  • 3,006 Answers
Your camera uses SD memory cards. On one edge is a slider switch: towards the electrical contacts is the unlocked position and away from them is locked.
Unfortunately, the switch is easy to move accidentally and it's also easy for it to appear to be unlocked when it isn't. Like any mechanical component it's also possible for the switch to fail.
If the switch is in the locked position then slide it fully to the unlocked position; if it's already in the unlocked position, slide it fully to the locked position and then fully back again. There should be a soft click at each end of the switch travel, if not then the switch is definitely faulty or obstructed.
If that fails, then try looking closely at the switch in both positions to ensure that there is no debris obstructing its movement, if not then check the electrical contacts to ensure that they're completely clean and grease-free. Don't touch the contacts with your bare skin, but if the contacts need cleaning then a cotton bud (Q-tip) moistened with a little alcohol or methylated spirits can be used to clean them.
If you still have no fix, then try a different SD card as yours may have an irreparable faulty switch. If the card does prove to be faulty then on most major brands you may be able to return them to the manufacturer for exchange: I've found that they will often do this on a goodwill basis even if the card is out of warranty.
If all options regarding the memory card are unsuccessful, then you have a faulty camera and further remedies require either a professional repair or replacement of the camera.
I hope that my answer has been of use and has given you additional options to fix your problem. Please take a moment to rate my reply.
Posted on Oct 01, 2010
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
I cant take pictures write protect keeps coming up on screen
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 06, 2014 | GE X5 Digital Camera
PROTECTED CARD CANNOT DELETE PICTURE
Dec 03, 2013 | Fuji Finepix S1500 10.0 Megapixel 12x...
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
I have a Kodak Easy Share C182 . I want to delete some pictures and it tells me to remove protection to delete, and it also tells me image is protected please tellmje stepby step how to clear this...
The most common cause for telling you that the card is locked is having the tiny slide switch on the side of the card in the wrong position.
- see photo below:
Set the lock slider to locked or unlocked.man-3ds-sdcardlockswitch-287-181.png
  • The down position will enable write-protection, locking the card.
  • The up position will unlock the card, enabling you to save and erase data on the card
kodak-easy-idhgrcvb3gwnj1x0htsxmiux-2-2.jpgthe tiny slider is labeled with "Lock"
SD memory card lock Nikon Knowledgebase
Dec 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
I cannot delete a picture as the screen says file protected. How do I remove?
if you cant delete any pictures then your sd card is locked which means you take it out and slide the little movable plastic,
if its one pic then you must unlock it in the properties menu
Jul 28, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
My cam keeps coming up with memory card write protected. How to get rid of it and also i cant delete any of the pics.
You have not mentioned the model number but this will help if your camera takes SD or SDHD cards.
Do you know that the SD card has a little switch on its side?
It is a small sliding thing on the other side from the cut out corner.
If this is in the lock position it will stop you saving your pictures to the card. This is to protect pictures that you want to keep.
To save pictures to the card the switch must be in the up position.
Feb 02, 2010 | Cameras
Fujifilem Z20fd I cant turn the card protection off which appears
Is your flash working? Do you have the flash turned on?
Jul 11, 2009 | Fuji Finepix Z20fd Digital Camera
Protected card pops up and i can't take or delete any pictures, but i can look through the pictures.
remove the card. there is usually a switch on the side. turn it to the other position.
Apr 19, 2009 | Kodak EasyShare V1073 Digital Camera
When I try to delete my pictures, the screen says memory card is write protected. i cant take pictures or delete them
What camera? What kind of card? SD cards have a sliding switch along one edge. Slide it away from the contacts.
Sep 11, 2008 | Nikon Cameras
Cameras Logo
23 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
