My problem is with the laptop screen. Moving the lid blanks out the display. Sometimes typing on the keyboard makes the scrren flicker. Someone told me that a cable may be loose or is breaking. Any solutions?
    President:
  • 2,992 Answers
The display in a laptop connects to the motherboard by a flexible cable that passes next to one of the hinges. Because of the flexing when you open and close the lid, wires in the cable can break and cause the trouble you're seeing.
The cure is to replace the cable. It's not difficult to do, but it's not always easy to get a replacement. In some brands and models, the cable isn't available except as part of the complete display. This may be quite expensive. If a replacement cable is available, you need to be sure it's the right one for the display panel used in the computer. The same model computer may use different parts depending on when and where it was made. Using the wrong display cable won't damage anything, but the display won't work correctly.
You don't give the make and model of your laptop so I can't tell you any more. But you can search online for "replacement display cable" for your specific computer and see what's available. There are many websites offering parts and how-to information, so you may find what you need.
Good luck with the repair, and thanks for using Fixya!
Posted on Oct 01, 2010
My laptop keeps flickering
First thing is to wiggle the lid and see if that affects it. If it does then the cable in the laptop that connects the bottom board to the display is bad. If it does not affect it, connect another monitor to the external connection to the laptop and see if it works. IF it does it might be the lights in the display that are going out or the power unit called the inverter that is in the lid
Jan 02, 2013 | Toshiba IBM 12P3878 THINKPAD T20 INTEL...
Compaq presario cq60 screen been flickering ocassionally then coming on, now flickering then going blank, any ideas please.
Could be a loose cable. Over time with the openning and closing of the cover the video cable is moving and in a few cases can become loose or pinched. If it is pinched it may need to be replaced. If it is just loose then it is fairly simple to remove the plastic piece above the keyboard and reset the video cable. Sometimes there are screws holding it in place but usually that piece is just snapped in place.
Apr 05, 2011 | Compaq Presario CQ60-220US PC Laptop
My computer keeps flashing the blue lights on and off,screen blank,not coming on tried to take battery off hold down start button connect to ac nothing happens same problem
Sounds like video card or video cable is faulty or loose. Is screen always blank no matter what you try? Were you getting intermittent screen flickering. There is a ribbon cable that runs from base to lid that sometimes get worn or loose from constant open/close of the lid. Try cranking lid to different positions while trying to boot up. You maybe able to find a video card under one of the covers on bottom. push card all the way inward to make sure it is seated correctly.
Dec 02, 2010 | Computers & Internet
Has a Toshiba Tecra 9000 won't power up. Power light on front is blanking which appears to be a code 3-3-2
The problem is cause due to one of the following: the backlight or the display, check your monitor brightness settings. Sometimes your brightness may accidentally have been all the way turned down, resulting in a blank/dark screen. The monitor controls are on the keyboard, directly above the numeric keys.
Look closely at your laptop's screen if the steps do not restore power to it and if it remains blank. Can you see a faint image on the screen? If so, the backlight may be off due to the LCD "lid close" detector malfunctioning. This malfunction likely happened due to the lid close switch being stuck in the "closed" position even though the lid is open. The switch is located beside the LCD's screen hinges, and tapping the switch a few times should unstick it.
Use an S-Video cable and plug your laptop up to an external monitor, such as your television set. With the laptop and TV hooked up, turn both on and see if your computer's desktop is displayed on the TV. You can also use a fifteen ( 15 )pin monitor desktop monitor by connecting it to the blue fifteen ( 15 ) connector at the side of the laptop if you cannot see anything on screen it is the display problem. If it is, your laptop's display needs to be replaced. If not, your motherboard and/or video subsystem may need to be completely removed and replaced.
Aug 31, 2010 | Computers & Internet
The monitor goes black but the power stays on.
It sounds as if you have a loose connection on the ribbon cable going to the screen, or under the keyboard. To check the latter, gently press on the group of keys on the left side of the keyboard
QWERT
ASDFG
ZXCVB
If the screen comes back on, then the problem is with the connection under the keyboard. If not, the problem could be with the connection behind the screen. Also, there could be a problem with the inverter. Hope this helps.
Apr 16, 2010 | HP Pavilion dv6000z Notebook
HP nx7000 display sometimes still or sometimes flickering horizontal lines then goes and says blank
It appears the video cable connector needs to be seated properly, it may be loose. The connector would be located near to bottom of the screen on the motherboard between the hinge and the top edge of the keyboard.
Depending upon the model of the laptop there is a plastic panel which houses push buttons and indicator lights that is located between the top edge of the keyboard and the bottom of the LCD screen. There are screws at the bottom of the laptop and possible screws on the back next to the hinge securing this panel. This panel would also have small plastic retaining clips locking it into place. You need a thin blade to lift this panel up, be careful not to crack the panel.
Once you remove this panel you see this video connector and cable. the connector may also be held in place with a screw and plate.
Jun 03, 2009 | HP Compaq Business Notebook nx7000
Hp Laptop screen flicker
I am sure that the issue is related to the cable that connects to the LCD Display or the LCD Backlight.
There should be some connection shortage because of which the LCD flickers few times as stated by dan231.
I Recommend you to get the Notebook examined as soon as possible before something really goes wrong...
Dec 05, 2008 | HP Pavilion dv6000z Notebook
Hi, i noticed that when I unplugged my HP the screen stopped flickering. I then re-plugged in the power, when to the Nvidia control settings, to PowerMizer, and changed 'ac outlet' to Maximum Power Saving.
Not the world's greatest solution, but hey, working laptop now.
Cheers,
Andy.
Nov 21, 2007 | HP Pavilion zd8000 Notebook
Dell pc not working
Try to clear first cmos settings and if it wont work soo u have a problem with VGA OR MOTHERBORARD
Nov 04, 2007 | Compaq Presario Notebook
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
