Question about Olivetti wireless All-In-One InkJet Printer
Trying to scan but it says "you cannot scan because no device was detected", but I can print ok. Whats up?
Kodak 5300 printer has stopped being able to scan, although it detects documents for copying ok. Tried to recalibrate and printed calibration page, but when inserted in scanner, get message, "Calibration...
try to do a power recycle. if still not able to do scan then printer needs replacement. Call their technical support, and get it replaced for free if its in warranty
May 27, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printer works scanner does not
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Scanner:
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
Aug 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Will not let me scan documents
install the software first and then you will be able to scan its just that the scan options are not getting detected from the software on the computer that assigns the scanning options.
IF the software is installed then open hp solution centre and point to settings.Then point to scan settings and click on scan to setup and move all the items on the left to the right by selecting each one and pressing the right arrow button and click on ok and now check you will be able to scan
Jun 15, 2009 | HP Officejet 7210 All-In-One InkJet...
Printer does not print scanned objects
try uninstalling the printer drivers from the device manager and then try reinstalling it.seems to be an issue with the printer drivers.
If you wannt any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Jun 14, 2009 | HP LaserJet 1018 Printer
Samsung scx-4100 scanner error - cannot detect device "Samsung.."
I just fixed this problem for my computer. Try installing the scanner driver. You probably have the printer driver installed but the scanner driver is needed for Smarthru
http://www.samsung.com/us/support/download/supportDown.do?group=&type=&subtype=&model_nm=SCX-4100&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010300&disp_nm=SCX-4100&model_cd=&menu=download
Jan 05, 2009 | Samsung SCX-4100 All-In-One Laser Printer
USB malfunctioned message
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly
Nov 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Aligning cartridges
first ckeck out your cartager are ok if your cartager are ok then when the align page print it will scan and once the align page is detected , align page printing will be stop.
Jul 06, 2008 | HP PSC 2210 All-In-One InkJet Printer
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Olivetti wireless All-In-One InkJet Printer Logo
93 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
