WLAN program Only way to enable WLAN feature on my Fuji laptop is to hit Fn / F1 whch then runs a program enabling me to switch on wireless or bluetooth. Can someone tell me what program hitting Fn / F1 runs (so that I can create a desktop shortcut rathe than hitting Fn / F1 as I often use the laptop via separate keyboard / monitor with the lid closed). Many thanks in advance ! Simon.
  • Anonymous Mar 25, 2014
    i have a problem fn+f1 not working on sony laptop
  • 868 Answers
Go into your hot keys program and make the change there.
Posted on May 26, 2008
Do you need to manually turn wireless on on laptop?
Yes there is a switch for enabling and disabling wireless on laptops. For Packard Easynote L4 the wireless can be enabled by doing the following actions:
1.press the Fn key (which is in the bottom lefthand corner of the keypad) and press F1(function) key together (Fn + F1)
2. this should enable wireless on your computer.
May 21, 2012 | Packard Bell Computers & Internet
Tip
Lenovo G430/ G530 Function keys
<p><span>The following describes the features of each function key.</SPAN><br> <p><b><span>Fn + F1: </SPAN></B><span>Put your computer in sleep mode.</SPAN><br> <p><b><span>Fn + F2: </SPAN></B><span>Turn off/on the LCD screen back light.</SPAN><br> <p><b><span>Fn + F3: </SPAN></B><span>Shift to other connected display devices.</SPAN><br> <p><b><span>Fn + F4: </SPAN></B><span>Switch between wide screen and normal mode.</SPAN><br> <p><b><span>Fn + F5: </SPAN></B><span>Enable/disable the built-in wireless device feature.</SPAN><br> <p><b><span>Fn + F8: </SPAN></B><span>Enable/disable the touch pad.</SPAN><br> <p><b><span>Fn + F9: </SPAN></B><span>Play/pause Media Player playback.</SPAN><br> <p><b><span>Fn + F10: </SPAN></B><span>Stop Media Player playback.</SPAN><br> <p><b><span>Fn + F11: </SPAN></B><span>Skip to the previous track.</SPAN><br> <p><b><span>Fn + F12: </SPAN></B><span>Skip to the next track.</SPAN><br> <p><b><span>Fn + Insert/NmLk: </SPAN></B><span>Enable/disable the Numeric keypad.</SPAN><br> <p><b><span>Fn +Delete/ScrLk: </SPAN></B><span>Enable/disable Scroll Lock.</SPAN><br> <p><b><span>Fn + PrtSc/SysRq: </SPAN></B><span>System request.</SPAN><br> <p><b><span>Fn + up/down arrow: </SPAN></B><span>Increase/decrease display brightness.</SPAN><br> <p><b><span>Fn + right/left arrow: </SPAN></B><span>Increase/decrease computer volume.</SPAN><br> <p><b><span>Fn + PgUp: </SPAN></B><span>Move the cursor to the head of the line.</SPAN><br> <p><b><span>Fn + PgDn: </SPAN></B><span>Move the cursor to the end of the line.</SPAN>
on Jan 19, 2011 | Computers & Internet
How to enable my wireless adapter
There should be a wireless switch either on the side of the laptop or at the front of it. Turn the switch on to enable the wireless.
Once the switch is turned on there are keystrokes you can hit that toggles the wireless on and off. Normally you would Press and Hold the FN function key then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless icon )))) on it or it might be the icon of a tower with the wireless signal )))) on it.
When you toggle the wireless watch your screen because it normally will display Wireless On or Wireless Off as you toggle it with the keystrokes.
Apr 20, 2012 | Acer Aspire One PC Notebook
How to enable a wireless connection on a laptop
LOL, hit the FN key and hold it down while you hit the function key (F1 thru F12) that has the wireless signal on it. The icon will look like )))))
Once you Press and Hold the FN function key then hit the correct key with the wireless icon ))) you can look at your lcd screen and it should say Wireless On or Wireless Off as you toggle by hitting the key.
Also make sure the wireless switch that is either on the side or front of the laptop is on if your model has one.
Apr 01, 2012 | Computers & Internet
How do i turn on my wireless on msi u130?
To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
May 14, 2011 | MSI Wind U100-030US Laptop
Cant get my wireless connection to work not sure
If this does not work, check if the driver is installed in your computer by going to the device manager. check under network adapters. If the driver is installed, uninstall the current driver and restart the computer.
If the issue still persists, you may download the driver update at the msi website: http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1474. Just make sure the driver you're downloading is compatible with yoru operating system
Apr 01, 2010 | MSI Wind U100-030US Laptop
Can't enable Dell Wireless 1390 WLAN Mini-Card
I had the exact same problem and went through the same steps that he did. It was only when I searched for a physical wireless switch (on the left side of my Dell D630) that the problem was solved. I didn't even know it was there and must have inadvertently knocked into the off position.
Dec 12, 2009 | Dell Inspiron 6400 Notebook
Can't turn on wireless on computer
which toshiba satellite pro ?
is wireless on at the laptop?
sometimes a combination: Button FN & F1-F12
try to connect router via ethernetcable:
inside routerconfiguration enable wlan
sometimes routers have a switch outside to enable/disable Wlan
is there a WLAN-LED at the router?
May 05, 2009 | Computers & Internet
How do i auto switchoff my lenovo y410 laptop
I'm not sure if your referring to sleep mode or not but I hope this helps There are several specialty key functions on the Lenovo Y410...here is a list....good Luck....please rate me ...The Fang
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
Feb 19, 2009 | Lenovo 3000 Y410 Notebook
More help needed pls !!!
I am not the first one that helped you.
If you have a program for your wireless you should be able to bypass the button. You can also check in your BIOS to see if there is a way to keep it on. To get into the BIOS you will have to hit the DEL key or one of the F keys.
May 29, 2008 | Computers & Internet
Computers & Internet Logo
304 people viewed this question
David Payne
David Payne
