Question about Amcor Aire AMS091HX Air Conditioner
How do you get to the ac connections on the aws091hx
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
You mean the charging ports, like most mini splits they will be inside the casing on the discharge and suction lines connected to your compressor. If you are not familiar with refrigerant charging i implore you not to try this with out all the proper tools and training.
Posted on Oct 02, 2010
My laptop is not powering on help
1.Connect the Ac adapter to a known good power outlet. Check the Power LED indicator on AC adapter (without plugging into the Notebook). We are only checking the power AC adapter to see if that is working.
2.If LED on the AC adapter is not lit (when unplugged from notebook), reseat the AC adapter brick and cable. If still there is no light on AC Adapter replace AC adapter and Power cord.
3.If LED on the AC Adapter goes off only after connecting to Notebook, the issue is with the motherboard. Replace Motherboard, DC-In port (AC adapter connector).
4.If the AC Adapter LED is always ON, take a technician's help and reseat the Power Button Board. You can refer to the Service Manual for details on how to reseat the Power Button Board. (NOTE: Before the notebook chassis is opened ensure all the power connections including battery and external devices are disconnected)
Jun 07, 2014 | Dell Inspiron Laptop 1440
Tip
LCD TV TROUBLE SHOOTING
1.Do not power on .
1 .1 Please check AC cable if connect to AC plug. Is true the connector don't connect to AC plug. Please connect it.
2.2 Please check AC cable if connect to AC power. Is true the AC cable don't connect to AC power. Please connect it.
3.3 Please check power board of fuse if broken. If the F1 fuse is broken, Please pull out the AC cable from AC power. Please check AC L power and AC N ground by multimeter, The read number is infinite, the fuse is broke. Then look up power board if not burn out place. Is true it. Please change power board or be changed power board.
2. The power on switch of green extinguish.
2.1 The power of led(indicator light) is red light, To touch power on key when indicator light wink. Is true that the power DC output have somewhere short circuit. Check connector J39,J31 .If not connector direction is wrong. Or the mainboard somewhere of power short circuit.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
on Feb 14, 2015 | iLO Televison & Video
Studio 1537 touch power button wont work
1. remove battery and ac adapter 2. connect the ac adapter to a different power socket without connecting to laptop. just check if the power led on the ac adapter will lit on. 3. if ac adapter led is on, connect ac adapter alone without the battery then try to power on the laptop. check if the power button or the media controls lit on if not then replace motherboard.
Apr 20, 2010 | Dell Studio 1537 Laptop
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
Acer 5920 aspire wont start
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
When i connect ac outlet to my laptop then connect please can you
check that oulet is properly grounded and wired right!
Jun 25, 2009 | Computers & Internet
Ac adapter does not connect to battery
You either have a faulty ac adapter; a bad power supply in your laptop; a bad battery; or a blown LED indicator light.
1. If the connection is not loose when you plug in your ac adapter try letting the laptop charge for a while. (If you are using the correct ac adapter)
2. Try removing your battery and using the ac adapter. If this works the battery is bad.
3. Try a new ac adapter.
4. Power supply is bad
Jun 05, 2009 | Dell Inspiron E1505 Notebook
Connecting a reciever to an amps unswitched ac outlet
Its safe to connect your receiver to amplifier's AC socket / outlet. These units has 2 type of AC sockets, Switched and Unswithced. Switched AC outlet can be On-Off by unit itself.
Feel free to ask any more question.
Sep 06, 2008 | Audio Players & Recorders
Amcor Aire AMS091HX Air Conditioner Logo
51 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
