Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a Sears Craftsman lawn tractor 917.256531 model 28N707 type 0173-01 Briggs and Stratton engine. It was running ok the summer of 2009 after doing an oil change this year - it seized up. tried new battery, new sparkplug etc but no go... any ideas. is there a repair manual available anywhere?
    Problem Solver:
  • 8 Answers
Make sure you did not over fill engine oil, it can not go above top of cross hatch on dipstick, also you must use SAE30 oil for summer if not avalible you can use 10W 30. check oil on dipstick if above top of full mark then drain oil to just below top of full mark then try to start engine, if it starts problem solved if not then try to turn engine by hand in clockwise rotation looking from front/flywheel side of engine, if no movement then turn counter clockwise, if flywheel/crankshaft does not turn but notice very little movement from flywheel/crankshaft then jack front of tractor apprximately two feet, remove spark plug and spray PB rust buster (avalible at any autoparts store) into cylinder and try to fill cylinder as much as possible and let PB rust buster soak for 2 hours then try to turn engine in reverse direction of rotation (counter clockwise) 4 to 8 turns, then (with spark plug still removed) crank engine with starter and it should turn freely, if not and still seized then you have internal mechanical failure. Engine must be disassembled and inspected. If repair of engine is expensive go to mower shop and check their tractor junk yard for used engine with same model number, the peaple there should be able to help you.
I hope this info helped.
Posted on Dec 17, 2011
  • 760 Answers
Make sure you didn't overfill oil. You can download a manual here: http://www.managemylife.com/mmh/owner_manuals/27208/CRAFTSMAN-Lawn-Tractor-L0808359?brand_name_search=917256531+CRAFTSMAN
You can find parts at www.searspartsdirect.com
Many manuals are listed on page once you look parts
Posted on Oct 02, 2010
Try to take the piston rings out and get new ones
Posted on Jul 11, 2013
I Need the wiring diagram for a sears riding mower.
Posted on Jul 05, 2011
Did a Tune-up, now the Starter just Free Spins, Bendix not engaging, How to Fix, without Replacing Starter?
Try the starter off the mower to see if the bendix works. See if there is any adjustment at the starter mount, play in the mounting holes.
Aug 29, 2015 | Craftsman Garden
Tip
2008 Craftsman lawn tractor
Tip for 2008 Craftsman lawn tractor that runs for about 30 minutes then starts to cut out and dies, and will not restart. These tractors have a defective gas cap that will not vent. Simply remove gas cap and reinstall loosely. The best fix is replace gas cap. If your tractor is less than two years old Sears will replace it free. preview_graphic.jpg
on Jul 30, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
WHAT WEIGHT OF OIL IS NEEDED FOR A YS4500 W/ A 21 HP BRIGGS AND STRATTON MOTOR
I have used 30 WT oil in all my 4 cycle engines. You could google Briggs & stratton to get some info. Sears will sell you an operators manual. Try googling Sears, you might get lucky & get the manual for free..
Louie Almond
Mar 27, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Mower cutting off when the engine heats up (Sears Craftsman)
sounds like you have magneto getting hot,,, next time it do it,, let it cool off for about 2 hours see if crank and run again till shut off,, if if does replace magneto,, hope this help,, good luck
Aug 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,940 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
