Question about Kohler K-T396-4-BRZ Devonshire Single Handle Rite Temp Shower Only Trim Kit...
Low pressure and diverter not staying on - Kohler K-T396-4-BRZ Devonshire Single Handle Rite Temp Shower Only Trim Kit...
  • 37 Answers
Remove the temp handle first decorative handle then brass sleeve under that brass should slide straight out you will see the mixing housing witch is brass cup shape piece about the size of washing powder cap there will be a small black plastic screen there pull out clean and replace then put back together should have good pressure which will fix diverter problem
Posted on Nov 10, 2010
Diverter
Hi! Yes it sounds like the spray diverter needs replacing. Kohler .com will have this part online or you could try a plumbing supply shop.
Mar 29, 2014 | Kohler K-10413-VS Forte Single-Control...
Kohler Fairfax kitchen faucet has low flow pressure. Any suggestions? It's the faucet, not the water getting to the faucet that has the low pressure.
First thing to check is if it has a strainer on the spout that has debris. The second thing is if you have a sprayer attachment the diverter valve is a chronic problem with kitchen faucets.
Dec 29, 2010 | Kohler Fairfax Single Control Lavatory...
I have a two handled price pfister kitchen faucet and replaced the cartridges and now have low water pressure what did i do wrong?
probably the diverter, order from mfg & replace or you can disassemble diverter and replace internal white part and O ring which is what I did and worked great
Oct 04, 2010 | Price Pfister Plumbing
Shower/Tub Diverter Value Low Water Pressure
I had the same problem. I discovered that an O ring was missing (or I lost it without noticing) from a new diverter that I installed. Just got an O ring that fits on the threaded part of the collar where it meets the pipe. Worked fine. Amazing how a little plastic piece could make such a difference.
Jan 25, 2010 | Eljer Arlington Non-Jetted Acrylic Bath...
Heatslave diverter valve
clicking rads are due to pipe expansion when getting hot.
If the hot water [secondary circuit] gets hot and the boiler stays on [does not keep going on and off] even with a constant low water flow then the diverter should be ok.
there is a valve to prevent the primary circuit [central heating] [ CH] from sending water to the rads. this or its control may be at fault.
both the
Both the CH pipes to & from the boiler should have manual valves to turn off. do this then try the hot tap-full on. If the boiler goes into overheat mode and the overheat stat kicks in to turn the boiler off -- then :-
Check also the heat exchanger, it may be furred up especially if you are in a hard water area. It means taking it off and manually checking [pour water through] If you're lucky it will be just muck to be forced out with hose pipe pressure, if not a new one
Sep 06, 2009 | Water Heaters
Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Aug 31, 2009 | Plumbing
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Fuel Problem
fuel pressure regulator? This diverts excess pressure from the rail back to the tank. When they wear out they usually stay stuck open thus diverting all pressure back to the tank. Pressure tests do not reveal this as pressure is checked before the rail not in it. I do believe you have a bad fuel regulator. They are 75US ouch.
Dec 06, 2008 | 1988 Ford Ranger
Low Water Pressure in Kitchen Faucet
Ihad the same problem. It is not the screen. What you need to do is get a spray diverter the old one disintergated and is blocking the flow. You have to take the collar off and underneath is the diverter. This is after you take the ball and rings out.
Oct 25, 2008 | Plumbing
Kohler K-T396-4-BRZ Devonshire Single Handle Rite Temp Shower Only Trim Kit... Logo
113 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
