Question about Columbia All Sport Digital watch
Need to set time on CL-5017
Instructions for other Columbia models (push light button, etc.) don't apply... This model has a Set button upper left, but despite Mode,Set and Reset buttons I still can't get to where the numbers flash to reset. Don't lose the instructions. Help appreciated!
  • 1 more comment
  • Anonymous Jun 08, 2008
    How do we set the time?
  • taytaye Jun 08, 2008
    How do we set the time on a Columbia CL-5017?
  • Anonymous Nov 26, 2008
    I have the 5026 model & I have the same issue on "how do you set the time!!
Columbia website was actually able to provide the instruction sheet, although it wasn't easy to get to it - the one that comes up is not the answer for all models. I tried to submit as an email to the site, and they flipped me right to the correct instructions. Strange, but it solved my problem!
Posted on May 28, 2008
Thank you so much for sharing with us your findings. Or, at the very least - a link to the page buried, obviously, deep within the Columbia website.
And for wasting the 6 minutes it took me to find this useless post I offer my thanx as well.
Posted on Jul 13, 2008
I cant set the time on my adidas duramo watch. It says 'offset' and below it says '1H'
This has already been posted on Fixya, so I take no credit for it. I've put the original reply below :-
Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
Aug 31, 2017 | Adidas Watches
Set date on 1440 sports watch 504-t5k085
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
Mar 01, 2012 | Timex 1440 Nylon watch
Cannot set time on 45/7012
Hold the reset button (upper left button) until the seconds start to blink. To go to the hours, push the mode button (lower left button). To set the hour, push the ST/STP button (upper right button) to the desired hour. To go to the minutes, push the mode button again, set the minutes with ST/STP button. To go to the date, push the mode button, set with the ST/STP button. Once done, simply hit the reset button to complete. Hope this helps!
Mar 13, 2011 | Armitron Watches
How do you change the time setting to 24 hours?
  • Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  • Step 2 Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  • Step 3 Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  • Step 4 Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  • Step 5 Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
  • Aug 17, 2010 | Columbia All Sport Digi Watch l
    Need instructions for my sr927w accurist watch
    QUICKSTART - SET THE TIME
    1. Push the bottom right hand button until the mode hand indicator points to TME.
    2. Press and hold the upper left button for three
    seconds. The hour and minute hand will retract to the 12
    O’clock position.
    3. Select the time zone on the digital display by pressing the
    upper right button or the lower left button.
    4. Pull the bottom right button out one click. The bottom part of
    the digital display will start flashing. Press the
    bottom left button to adjust for daylight saving time.
    5. Press the upper right button. You will see the seconds
    flashing on the lower half of the digital display. Press the lower
    left button to reset the seconds to 00.
    6. Press the upper right button. You will see the minutes
    flashing. Press the lower left button to set the minutes to your
    current time.
    7. Press the upper right button. You will see the hours flashing.
    Press the lower left button to set the hours to your current time.
    8. Press the upper right button. You will see 12H or 24H
    flashing. Press the lower left button to switch between 12 hour
    and 24 hour.
    9. Push the lower right button back in.
    SET THE CALENDAR
    indicator points to CAL.
    2. Press and hold the upper left button for three seconds. The
    hour and minute hand will retract to the 12 O’clock position.
    4. Pull the bottom right button out one click. You will see the
    month flashing on the digital display. Press the lower left button
    to change the month.
    5. Press the upper right button and the date will begin flashing.
    Press the lower left button to change the date.
    6. Press the upper right button. You will see the year flashing.
    Press the lower left button to change the year.
    7. Push the lower right button back in.
    SET THE ALARMS
    indicator points to AL1, AL2 or AL3.
    4. Pull the lower right button out one click. You will see ON or
    OF flashing on the digital display. Press the lower left button to
    turn the alarm on or off.
    5. Press the upper right button. You will see the hours flashing.
    Press the lower left button to change the hour.
    flashing. Press the lower left button to change the minutes.
    SET THE TIMEZONE
    1. Setting the time zones allows you to add or remove cities on
    the digital display or switch between daylight saving and
    standard time. Begin by pressing the lower right button to move
    the mode hand indicator to SET mode on the bottom dial.
    2. If the hour or minute hands are obscuring the digital display,
    press and hold the upper left button for three seconds. This will
    cause the hour and minute hand to retract to the 12 O’clock
    position.
    3. Now pull the lower right button out one click. You will see the
    digital display flashing. Press the upper left button to select
    SET to display the city or OFF to not display the city. Press the
    lower left button to turn summer time on or off. Summer time is
    indicated on the lower part of the digital display. Daylight
    savings time must be manually set for each city.
    4. Pressing the upper right button will allow you to scroll
    through all the cities. After setting, push the lower right button
    back in.
    USING THE TIMER
    1. Press the lower right button to move the mode hand
    indicator to TMR mode on the mode dial.
    position.
    3. Pull the lower right button out one click. You will see the
    minutes flashing in the digital display. Change the minutes by
    pressing the lower left button. Once you have set the minutes
    on the timer, push the lower right button back in.
    4. Pressing the upper right button starts and stops the timer.
    5. Press the lower left button when the timer is stopped to reset
    the timer to its initial preset time.
    USING THE CHRONOGRAPH
    1. To use the chronograph press the lower right button to move
    the mode indicator hand to CHR mode on the mode dial.
    3 .To start or stop the chronograph press the upper right
    button. If you press the lower left button it will display the split
    time for 10 seconds.
    4. When the chronograph is stopped press the lower left button
    to reset back to zero.
    SET THE TIME ZONE
    the mode indicator hand to SET mode on the bottom dial.
    savings time must be manually set for each city..
    through all the cities. After setting, Push the lower right button
    back in one click.
    Hope this helps. =)
    Oct 10, 2009 | Bulova Watch
    How to set time on columbia cl-5008 watch lost manual
    Press and hold "set" until the "Chime" screen comes up.
    Let off "set" and then press "mode" - This will take you to the clock. adjust the numbers by using "st/sp" and "reset". Use the mode button to cycle through the hour, min, sec and date.
    This was a pain in the **** until I figured it out.
    Nov 10, 2008 | Columbia All Sport Digital watch
    Timex 1440 sports digital watch time setting
    1. Press and hold the mode button until it starts to blink, then release.
    2. First the alarm time will come up.
    3. Press the mode button once to get to the time and date.
    4. The seconds will flash first.
    5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
    6. Press the lap/reset button to change the values.
    7. When done, press the mode button again to return to normal.
    Mar 09, 2008 | Timex 1440 Nylon watch
    Columbia Watch CL-5030
    Hold the light button (top left hand) for a few seconds and the adjustment mode becomes available.
    Dec 25, 2007 | Columbia All Sport Digital watch
    How to set time on Diesel DZ 7071 Watch
    Just figured it out!! Press and hold Set/El button. Wait until LIGHT On/Off (or similar) flashes on screen. When it does then press the Mode button to scroll through various functions including setting the time. Hope this makes sense and helps
    Dec 20, 2007 | Watches
    Casio g-shock watch
    http://world.casio.com/wat/download/en/manual/
    try for the manual from here.
    riz.
    Nov 06, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
    Columbia All Sport Digital watch Logo
    1,160 people viewed this question
    Top Columbia Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Columbia Watch Expert? Answer questions, earn points and help others
