Question about Bowflex Revolution Home Gym
I am looking for one of the rubber feet for a Bowflex Revolution machine. Do you know where I could purchase one?
How to determine how old a bowflex revolution is?
Look for the Model number and use google search. If that does not help or it takes a bit of time to find your answer then search for the model number at amazon.com. Amazon typically has detailed information on a product including dates.
May 28, 2014 | Bowflex Exercise & Fitness
Tip
Bowflex Revolution Assembly Manual Download
Download Bowflex Revolution Assembly Manual
Would you like to review the features of the Bowflex Revolution Home Gym?
Have you lost your Bowflex Revolution Home Gym Assembly Manual?
Would you like a digital, searchable, pdf version of the Bowflex Revolution Home Gym Assembly Guide?
Follow this link (& click FREE) to download a pdf version of the Bowflex Revolution Home Gym Assembly documentation.
I hope that helps.
___________________________________________
Download Bowflex Revolution Users Manual
on Jul 03, 2010 | Exercise & Fitness
Tip
Bowflex Revolution User Manual Download
Download Bowflex Revolution User Manual
Have you lost your Bowflex Revolution Home Gym Owners Manual?
Would you like a digital, searchable, pdf version of the Bowflex Revolution Home Gym Users Guide?
Follow this link (& click FREE) to download a pdf version of the Bowflex Revolution Home Gym documentation.
I hope that helps.
How do I fold the bowflex revolution
There is a pop pin on the support at the end of the seat rail that must be pulled out to fold a Revolution up. You might want to download the complete operation manual, it is available directly from the manufacturer at bowflexcatalog.com. The product manual link is at the bottom of the page.
Jan 05, 2011 | Bowflex Revolution Home Gym
Tip
I hope that helps.
on Jul 03, 2010 | Bowflex Revolution Home Gym
Tip
I hope that helps.
I put one the first weight and locked it in i didn't know that you had to put all six and then lock it in. How do i take the one i put on off and start over
You should be able to take off the plates by turning them the opposite direction as putting them on. If you look at the plate you'll see the grooves that lock each one together. You just need to twist the plate you want off and twist it out of the grooves. Once out of the grooves it will turn back to normal, releasing the tension on the bands inside. You can then just slide it off the bar. The perm attached 5# plate tends to turn too. You need that one to be stationary. If you can't do it alone, have someone hold the perm 5# plate steady as you turn 'off' the additional plates.
May 03, 2009 | Bowflex Revolution Home Gym
Error Code E1
I had the same error message E1 at 10 seconds according to the LCD display on an older Treadclimber TC1000. I called Bowflex 1-800-792-6784 and first thing they told me was to check the drive sensor on the back left corner of machine. It is two wires connected by 2 white connectors that snap together. The end of the sensor has a rubber cap that is supposed to be approximately 1/8 inch from the drive pulley. The rubber cap plugs into a small hole within the "firewall" of the drive pulley, but the end of the cap does not actually touch anything. They can email you a picture of it. If it ever gets knocked loose, the machine will register this e1 error, in some cases- hope this helps.getattachment.aspx&hm__qs=file%3d3d2f2ee0-2668-46ea-b32c-db049d56cb37.jpg%26ct%3daw1hz2uvanblzw_3d_3d%26name%3daw1hz2uwmdiuanbn%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253aimage002.jpg%254001c99c08.13bd6320&oneredir=1&ip=10.12.128.8&d=d6608&mf=0&a=01_0b590aaade5e800af268d347750ab151eca93264be20cd9ce2166e583b18cfe9
Jan 24, 2009 | Bowflex Treadclimber
Bowflex Revolution Home Gym Logo
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
