I have a samsung r60plus about 2 weeks old, no problems until today. the disc keeps ejecting itself after about 10 secongs of the drawer being closed. it opens itself even if there is no disc inside.
  • 134 Answers
Once there was a virus that was written to do that deliberately.. Do you have up to date anti virus? May pay to run a scan. There appears to be no problems with these notebooks reported on the net, so seems unlikely it's a common fault. On some notebooks you can remove the dvd/cd rom drive, so does your manual say anything about that? It may be a case of removing it & re-seating the drive. Good luck.
Posted on May 26, 2008
  • 139 Answers
Check setting other wise lose make some servicing then srew back n see
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Sony dav-hdx265- disc is stuck- door will not open
According to the Sony manual, a C-31 error code indicates that the disc is not inserted correctly. Their recommended fix is to restart the system and re-insert the disc correctly. That just leaves the problem of getting the disc out, right? If eject doesn't work, you may have to open the disk drawer manually. With single-disc systems this is fairly simple: there is always a small pinhole near the disc drawer, usually just below the right side of the drawer. Straighten a paper clip and stick it into the hole until the latch releases, then remove the disc and close the drawer. All should be fine from there on. I do not know if multi-disc systems have the same sort of release but that is where I would start.
Nov 24, 2013 | Sony BRAVIA DAV-HDX267W Theater System...
Why can't we get the dvd to eject?
Possibility 1 -
The laser light inside the DVD player is most probably no longer aligned and cannot read the beginning of the disk. Therefore it keep on trying to find the first line but it can't.
Possibilty 2 -
Your husband entered a pirated copy and sometimes the first few tracks are unreadable due to the lower quality of DVD-R used and it jams the laser light inside the DVD player.
What needs to be done is to unplug the DVD from its source and gently pull open the DVD drawer in order to remove the stuck disc inside. Once that is done, power up the unit and press on the "eject" bottom so that the drawer can close itself.
Good luck.
Aug 16, 2012 | Samsung DVD-V4600 DVD Player/VCR
My samsung Tablet is 10 wks old, a month after I got it, it started to shut itself off and stay off for and hour or two, then suddenly turn itself back on. It did this several times until I found a way to...
You should return the device. It sounds like a problem with the hardware or the software. A good many rooted versions of android exp. these same problems also.
Mar 21, 2011 | Samsung Galaxy Tab Tablet PC
The disc will not eject and the wii says to insert a disc
Try holding down the eject button for at least 10 seconds after turning on the console. If that doesn't work (or you've already tried that). Try the following steps.
1. Unplug Wii from power outlet.
2. Plug in Wii again.
3. Press power button.
4. Press Eject button for at least 10 seconds.
5. If the disc doesn't eject try holding down the power button for 10 seconds and then the eject button again.
If that fails then either return the console to exchange for a new one or contact Nintendo consumer support. Info follows:
Nintendo Consumer Service Contact Information:
Telephone: 1-800-255-3700
Email webform:
I wouldn't attempt to manually remove the disc (by trying to disassemble your Wii) as it may void your warranty. It could simply be a faulty console in which case Nintendo should replace it within 2 weeks (according to posts I've read). It seems to be a somewhat common problem.
If holding down the eject button doesn't work, there's really not much else you can do. Sometimes unplugging and replugging does the trick.
I've had problems with discs not ejecting and some combination of the steps I wrote above solved the problem.
It is possible that you inserted the disc incorrectly. That would account for the error message "Unable to read the disc" or "Disc could not be read." But it should've ejected on its own.
Before calling Nintendo Service you can also see if their Support site has any solutions. Try the link provided in the source.
Good luck.
Dec 29, 2010 | Nintendo Wii Console
L have a Samsung R60plus which keeps turning off
Go to the Contol Panel, select System and Maintenance, select Power Options, select (both) to make changes: Computer Sleep, and Power button. I hope this Fix it
Jan 21, 2010 | Computers & Internet
Unreadable disk
NO dont use a lense cleaner. chances are you are about to get the rrod, this hapeened to me. i suggest give the console about a week to cool down then try it again
Mar 13, 2009 | Microsoft Xbox 360 Console
Wharfdale dvdr24hd160f
Look at the door of your DVD shutter. There might be very small hole. This is an emergency Shutter open point. Make off your player, insert a long pin inside the hole, press it gently, you will notice that the shutter is openning, pull it out side, and take off your data DVD from the tray.
Mar 08, 2008 | Televison & Video
Xbox, not 360
try calling xbox customer support at 1-800-4myxbox and see what they say.
Jan 02, 2008 | Microsoft Xbox Console
Samsung DVDR122
I have exactly the same problem as above
Dec 17, 2007 | Samsung DVDR120 DVD Recorder
Computers & Internet Logo
David Payne
David Payne
