Question about Frigidaire ATF6000ES Front Load Washer
Fabric softener not being used. what could be the cause and fix for this problem... thanks
  • Frigidaire Master
  • 1,711 Answers
Remove the detergents drawer and clean it with warm water very well especialy the softener compartment.
Posted on Oct 01, 2010
Fabric softener leaking from bottom of washing machine
One possible cause.
Someone is pouring fabric softener in the washer's Bleach bezel.
Causing the bezel to become clogged and then overflow.
Apr 02, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
Water in slot for fabric softener wont drain. Always water in there. Lameez SA Jan2014
Remove the dispenser draw and wash it all out. The most likely cause is that fabric softener has congealed and blocked the dispenser. I hate what softeners do to machines with a vengeance. I would never put any fabric softener anywhere near my machine ever. They cause many problems that are not easily remedied.
Regards
John
Jan 30, 2014 | Bosch Washing Machines
Fabric softener ends up around rim of washer.
When you say you've cleaned both parts - have you poured hot water in and seen it actually drain out of the top peice while it was removed from the agitator? Have you poured hot water into the agitator with the top peice removed and seen it drain out of the holes? If not, repeated flushing (of the agitator) and soaking (of the top peice) with hot water as needed until is drains may be required. Until you can get water to drain out of both peices alone, it will work automatically. Once you have the water draining try again with a regular load of laundry and fabric softener. If it still doesn't work...
Since you've cleaned both parts (the non-removable and removeable top portion) of the agitator - it would suggest that the fabric softener dispenser's actuator inside the agitator is not functioning properly. The fabric softener isn't being released in the rinse (or at all really) and as a result of the centrifugal forces during the high speed spin cycle - it is causes the fabric softener to move up the sides of the dispenser and spray out of the top of the agitator onto the rim. This may be caused a mechanical or electrical failure in the washer or washer control. It will continue to work like this until it is fixed - so I suggest that you do not use the dispenser.
You will likely need to have the washer professionally serviced to have it begin working again. You can save the repair costs and either add the fabric softener yourself during the rinse cycle - or use "dryer sheets" in the dryer instead.
Feb 05, 2013 | Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
How to use fabric softener
On this machine the compartment is built to hold your softener until it is time to be dispensed. So put in your softener (and bleach if you are using it) at the beginning of the load when you are adding your detergent. The washer will flush the fabric softener cup during the rinse fill to make sure it comes in at the right time for you.
Hope this answers your question!
Jul 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite spraying fabric softener all over clothes and tub
hello mam
is this softner provided by the kenmore dealer if not please getit from them because they know whish softner should be used and for the spots use descaling powder and run the machine without loading clothes.
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
I am so disgusted with my fisher and paykel washer!! It has ruined many of my clothing items due to fabric softener...what is the deal with this washing machine? I have had Fisher and Paykel washer and...
Are you using the fabric softener setting when using fabric softener? If not the washer is not using enough water to dialute and disperse the liquid fabric softener. a traditional machine uses about 45 gallons of water fisher&paykel uses 20 gallons. If you use liquid softener you have to use fabric softener setting and negate the water efficiency of the machine. I had F&P for a few years till I moved and there are tips but I really liked mine. Hope that helps.
Jan 11, 2009 | Washing Machines
When should u add softener?
Dear seymour,
please rate this solution if it meets ur need else choose fixya.
Fabric softener is one of those things we don’t think much about, but use frequently. How does it work? How is it used? Fabric softener is essentially a chemical cocktail that helps soften the fibers in textiles. It makes them feel less harsh and has anti-soiling and anti-staining properties. With such names as Diethylenetriamine, Aminoethylethanolamine and Triethylenetetramine, these chemicals sound like something out of a science-fiction movie, but they are mostly byproducts of animal fats. Fabric softeners come in two types: liquids and dryer sheets. The liquid softeners are added to the rinse water for each load of clothes. Dryer sheets are paper or sponge-like pieces that are coated with the dry softener and are added to the dryer for every load. Some liquid softeners tout that they will leave clothes brighter and prevent discoloration from chlorine. These claims must, of course, be evaluated by each person.
Fabric softeners are used in any form to help make clothing feel softer and to prevent static cling. Anyone who has unloaded a batch of towels from the dryer in winter knows exactly what static cling is. Dryer sheets lubricate the textile fibers to reduce static electricity generated by the drying process. Liquid softeners serve much the same purpose.
There is a great amount of information about fabric softeners on the Internet, and while browsing, a person will undoubtedly come up on Web sites saying the chemicals in fabric softeners are dangerous and can cause a whole host of illnesses and allergies. There is no doubt that some people are allergic to the chemicals and/or dyes in fabric softener. They can cause rashes or upper respiratory distress. Some manufacturers have started producing dye and fragrance-free liquid fabric softeners in response to this problem. Some small companies also produce a vegetable-based, dye and fragrance-free softener that is biodegradable and less likely to cause allergic reactions. There are also some ways of softening the laundry without using any kind of commercial fabric softener. Vinegar and baking soda soften the fibers naturally. A person can add one-fourth cup baking soda to the load at the beginning of the wash cycle, and then a half-cup of white vinegar during the rinse cycle. Another home recipe suggests diluting 1 cup of glycerin in a gallon of water and using one-half cup of the mixture per load of laundry. Still another method uses three parts water to one part commercial hair conditioner. Fabric softener should only be used with standard fabrics. Fine washables such as linen or silk should not have any kind of fabric softeners used on them, if they are machine washable. The chemicals can destroy the look and feel of a fabric like linen, and dull colors in silk. However, most standard cotton and polyester blends are safe with the use of fabric softener. Dryer sheets are a blessing for socks and towels, since these items seem to be most susceptible to static cling. Liquid fabric softener can also usually be diluted to one-fourth strength in order make it last. There is usually no discernible loss of softness or increase in static cling when the softener is diluted. Each person needs to decide whether using a commercial fabric softener is appropriate. Those with allergies or very sensitive skin may want to consider a home recipe, since they are made of ingredients that are readily available. People also need to remember to keep the fabric softener from their fine or delicate washables, especially linen and silk.
Dec 17, 2008 | Admiral AW22 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
139 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
