Question about IBM Lenovo ThinkPad X60 Motherboard - 42W7697
I have a IBM X60 which has broken LCD. I replaced with a new one but the laptop won't turn on if the LCD cable is inserted in the bracket. And the same thing happen no matter whether the power plug of LCD screen is inserted in the inverter. The fan and hard drive spin for a few seconds and then everying is stopped. If I pull the LCD cable out of the LCD screen, everything is fine. Please let me know what happened.
  • jiehang Oct 01, 2010
    First, thank you for the answer. As I stated in my question, no matter if the inverter is used, the laptop won't start if the lcd cable is inserted in the screen. The ldd cable is a new cable as well.
  • jiehang Oct 03, 2010
    The laptop won't turn on even when the inverter is not plugged. As long as the LCD cable is inserted in the screen, the laptop won't t turn on. The laptop can start normally when the LCD screen is not connected with the LCD cable. I have tried the VGA ouput and it works.
  • 3,083 Answers
Not sure, but the inverter might be bad. Here's a site that explains how to check one:
http://www.fonerbooks.com/test.htm
It sure sounds like the power supply is getting loaded down when the inverter is plugged in, and I would concentrate on that item.
Good luck, and hope this helps.
Posted on Oct 02, 2010
  • IBM Master
  • 12,061 Answers
I think you may find it is the Inverter that is faulty, try replacing that unit and most likely your problem will be resolved.
When you plug it all in and the PC shuts down, that is because the special protection circuitry in the Power supply, is detecting a "Problem" (Usually a short circuit or a too large a current draw) and it shuts the system down. So this points to the Inverter, or maybe the backlight.
To prove your video card see if you can get the laptop to work on an external monitor with NO LCD inverter connected. If it is OKI, this then proves your actual Video Card, and more points to the LCD external drive.
Posted on Oct 01, 2010
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
When I power up IBM TP X60 tablet I get the bios password screen, a I dončt know the password. How I can remove it or bypass it ?
For IBM/Lenovo Password
there is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to made serial port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html
Thanks
Oct 07, 2010 | IBM ThinkPad X60 Tablet PC
I have a Lenovo x60 Tablet Computer and when the computer screen moves the mouse starts stuttering and the t messes up when typing.. also a blue screen comes up sometimes.
sounds like a loose lcd connector, or pinched cable.
the lcd connector is under the keyboard. remove the panel that has the power button on it, it should just pop off from one side to the other. the remove the 2 to 3 screws located at topof keyboard, plus remove 2 to 3 screws under laptop located in holesmarked with a big K maybe even circled. with keyboard out of way you will see the lcd cable connector, it should have a "paperclip" handle, pull it up then reseat the connector, reassemble and test.
Aug 12, 2010 | IBM ThinkPad X60 Tablet PC
My lapttop is stuck on the login window and I can
Removie battery and remove all the screws on the bottom by the Hard drive or dvd drive. You will see a white and red cable, depending on the year a green cable. Follow cable and disconnect it. It should disconnect the Bios and reset it. connect after 3 to 5 minutes
Jun 13, 2010 | Lenovo ThinkPad X60 Tablet PC
IBM X60 laptop won't start
It really does sound like a hardware problem, perhaps a motherboard/processor/memory issue. If there is no beeping but just humming that is just the fan and drives kicking up.
I would recommend you take it into a repair shop and have them diagnose the issue.
Mar 20, 2010 | IBM ThinkPad X60 Tablet PC
Hi, the backlight on my screen no longer turns on but i could see windows running so i know that the screen is not broken. i was thinking that the inverter is probably the problem, but if not how can i...
The backlight is normall part of the LCD panel assembly and is not normally changeable on its own (sadly) however here is a link to one being solf on ebay http://cgi.ebay.com.au/LCD-CCFL-Backlight-Lamp-for-IBM-lenovo-ThinkPad-X60-X61_W0QQitemZ250464679317QQcmdZViewItemQQimsxZ20090715?IMSfp=TL090715205001r13604
and here is a link to the X61 LCD dissassembly http://www.insidemylaptop.com/replace-broken-lcd-screen-lenovo-x60s-laptop/
After removing the LCD you will gently have to prise it apart to reveal the backlight assy. Hope this goes will for you.
Aug 11, 2009 | IBM ThinkPad X60 Tablet PC
I cannot get into original setting of IMB X60 lenovo thinkpad
you got a desktop hacker installed on your pc.
http://www.superantispyware.com/superantispyware.html?rid=3007
download the spyware and run a scan. it should solve the problem
Mar 30, 2009 | Lenovo ThinkPad X60 Notebook
Thinkpad x60 reboot fails. Error message: Media test failure
plz check the hard disk data cable(cable which is connected to motherboard), if changing the cable do not solve the problem your hard disk may be corrupt
Mar 01, 2009 | IBM ThinkPad X60 Tablet PC
IBM Lenovo ThinkPad X60 Motherboard - 42W7697 Logo
109 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
