Long time since I used one of these, and as plain paper faxes are so cheap now I do wonder why you persist with this old technology? You can purchase an all in one printer for under £50. Pick one with a built in LCD screen and you don't even need a PC.
Getting back to your current problem, it sounds as if the paper has been inserted the wrong way around. Try taking the roll out and checking again the correct way to put in the paper. Or maybe the paper roll has been out of its plastic protection for too long causing the paper to degrade. Once it has been exposed to light it is like a film for a camera, it is no good. If this has happened you may try unrolling two or three of the outer layers and cutting them off, and then reload the paper and try again. You may be lucky and find that only the top two layers have been damaged.
SOURCE: Recipient recieves a black page
I have seen the print cartridge not being seeted cause this problem.
Slightly lift up on the Laser Printer Cartridge and then pull it toward you, but do not remove it.
WARNING: The Fuser is hot! Use caution when you are working in this area. To prevent damage to the cartridge, do not expose it to light for more than a few minute.
CAUTION: Do not touch the green Photoreceptor Drum. Scratches or smudges on the Photoreceptor will result in poor copy quality and may shorten the life of the cartridge.
Then Unplug an replug in the machine.
SOURCE: Black page when copying and sending faxes.
You most likely have a bad SCANNER BLOCK. Not good!
SOURCE: My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
SOURCE: SHARP UX-A1000 - sends all BLACK page (to all
Noisy line? is all that strikes true when you ensure me it makes great photocopys, but then you receive OK, very strange, All the mechanisms for doing a local copy is the same as sending a fax the difference is the conversion to phone noise so it has to be electronic, I;d guess lightning/power surge, cant think of much else....sorry
