Reset bridge to different router without the disk.
  • 857 Answers
Follow these steps :
•1
Reset the bridge. Accomplish this by manually disconnecting the power source from the wall or the back of the bridge. Leave it disconnected for 30 seconds to a minute so that the software contained therein can fully reset. Reconnect the bridge and wait two to three minutes until the network is back up and running again. In many cases, a simple reset can solve your network-related bridge problems.
•2
Ascertain whether there is network activity on your computers. Accomplish this by looking at the back of each computer at the network card. There should be two lights next to your Ethernet port--at least one of these lights should be completely lit without flickering. This indicates that the network card in the machine is operational and ready to receive a signal, eliminating that as a possible problem source.
•3
Move the bridge to a different location to determine whether interference is preventing the network computers from receiving a proper signal. If possible, relocate the bridge to the same room in which the computers are located and try to reset the connection again.
•4
Determine whether the bridge has failed altogether or whether the wireless signal from the bridge has failed. Accomplish this by physically connecting the computers to the wireless bridge through the use of Ethernet cables. If this restores network connectivity, you know that the only problem with the bridge is the wireless signal emission.
Posted on Oct 01, 2010
I reset my router, so I lost my security. Can I secure it again with out the disk that came with it?
Yes you can. I will demo it done with a Cisco router. It shouldn't be much different.
Jan 27, 2013 | Belkin Computers & Internet
Wireless is nonexistant
You need to bridge mode your modem. And when set it to bridge mode already. Connect the dlink router. Access the gui of the router. Enter there your username and password. Powercycle modem, router and computer. Check connections. I f this didnt work, set again your modem to default, connect your router. Configure your router with username and password. Powercycle again. Check if it is working.
Jul 16, 2010 | D-Link DI-524 4 Port Wireless-G Router -...
I purchased two netgear wall plugged bridge XE102. They worked fine for one month. Now I get messages on my computer do not detect homeplug adapter. On my TV it say's is not hooked to the internet. What is...
I had the exact same problem those branded ones at our shop where one just stopped working all together.
THeres a couple of things to rule out so you can try some steps to figure it out.
Try changing the port on the router where the first plug is hooked into, if you can, try a direct connection without the plugs aswell. Also, try inserting the plugs in different outlets and see if anything has changed. If they're only a month old, they are still under warranty and you could get them replaced either through ytour place of purchase or from netgear aswell.
Apr 26, 2009 | NetGear XE102 Powerline Ethernet Adapter...
Dlink wireless router software download
http://support.dlink.com/downloads/#
You can select your router from that list to get most of the information. You can request another disk free of charge from d-link by contacting customer support.
Jan 11, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Bridging 2 different types of router
Yes, you can bridge two different brands of routers. It is not the router but the protocol that the router uses that makes it incompatible. But because of the way you are set up you will not have any problems with different brands. Both will use DHCP to get your IP address..
Dec 26, 2008 | Computers & Internet
Placing Sppedstream Modem 4200 in bridge mode
http://192.168.254.254/brgmode.html ...or if they have the gay firmware >.> go to http://speedstream/brgmode.html then click apply....now set your router to log in with your user information with a PPOE login...if your like me and using the dlg-4500 just go to setup and do internet wizard to set up easily...then your ready to go... it can take up to 10 minutes for your router to configure so give it time..and if it doesn't seem like it's working in that time...try cycling your power then check again...and if still not working, do a hard reset (hold reset till lights alternat from green to red) to reset to factor default (do it for your router too becfause it will still be set to sign into your isp for you)
Jun 14, 2008 | Siemens SpeedStream 4200 (13A4200001)...
ZyXEL Ethernet Bridge Won't Connect
the i =ndications are quite clear it's a concern with router's wireless reception...try to reconfig wireless settings on your router change channel to 1 if still the same router is not sending wireless signals properly..
Feb 13, 2008 | Computers & Internet
Two way routing.
You will always have a problem because the subnet is different. Your solution lies at the Server Level if you have two different servers one must become the 2BDC, other wise you will need more hardware to setup a bridge contact D-Link as to the equipment you will need.
Coach "J"
Have a great 2008!
Jan 08, 2008 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
146 people viewed this question
David Payne
David Payne
