Question about Dishwashers
It leaves about an inch of water after finishing, Hoses seem clear but the pump seems stiff to turn when i take out the filter, how can i get to the back of pump to clear it. do i need to turn the dishwater on its side to get access to it underneath
    Problem Solver:
  • 10 Answers
I WOULDNT TURN IT ON ITS SIDE IF IT HASNT FULLY EMPTIED. I WOULD TRY A DILUTED SOLUTION OF Mr MUSCLE DRAIN UN-BLOCKER. THEN RUN ON A FULL CYCLE STRAIGHT AWAY.
Posted on Oct 01, 2010
Speed queen washer filling slow
The rubber of the filter stick to the hose due to time and heat of the water. Try to move "wiggle" it with your fingers to get it unstuck. Can even use the handle of a teaspoon for more leverage but try not to damage the rubber seal as it will not seal proper again when connected the tap. Clean with a nylon brush. If found impossible to remove, leave it as installed but immerse the hose end with the filter in a half cup vinegar for a hour or so to dissolved the chalk residue. Brush again with a nylon brush. Chalk remover can also be bought over the counter - same as the tuff sold to clean chalk inside electrical kettles. If every thing failed sit down with the hose end with the filter in one hand and a thin but strong/stiff piece of wire in the other hand and pry open each hole formed by the grid of the mesh.
Aug 01, 2014 | Speed Queen Washing Machines
My saltwater pool turned agreenish color what do i do to fix it
If possible take a sample of the water to a pool shop. They will tell you what to add to clear water. Also filter should be cleaned as may be blocked with the green algae.
Jul 05, 2012 | Intex Automatic Salt Water System for ...
80% of the time the unit finishes with an inch of water still in the bottom. We always prewash dishes , so shouldn't be clogged drains and have only used the unit a dozen times because of the drying...
Hi
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. However, if it seems to be a lot more water then it is due to clogged drain filter or drain pump. Turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Hope this helps... Please post back for any further assistance.
Daniel
Nov 26, 2010 | Frigidaire Dishwashers
When we have finished the cycle there is water in the bottom of the machine, checked the filter this is clear opened the pipe work seems clear
its not uncommon to have water at the end of the programme providing the results are ok dont worry. most of the water is the drying steam condensing and running back to the sump. the dishwasher pumps this out at the begining of the next prog.
Aug 24, 2010 | Bosch 18 in. SRS43E02 Slim-Line Built-in...
My Dishwasher has a rapid flashing light
I get the same problem with a pepeating beep warning. Only solution I've found is to switch it off using off button then switch it back on. It waits a few seconds then finishes the program and drains. The dishes still seem to be quite damp after. Hope this helps
Jul 12, 2010 | Hoover Dishwashers
Water won't drain after cycle is done. Leaves 1-2 inches of water in bottom. Checked hose and its clear. Put hose going to disposal in bucket and water comes out when diswasher is cycling
it is easy track this path of water from bottom of m/c it will b afilter then small hoses to drain pump thenouter hoses <
thanks
Jul 13, 2009 | Dishwashers
Doesnt clean dishes, seems to be no water coming into machine
There should be about 2 inches of water in the bottom of the DW.  If it is filling but not washing the pump may be bad.  That might explain the loud noise (motor bearing).  I assume that the detergent cover is opening but no water is being sprayed to dissolve it.
May 31, 2009 | Dishwashers
Air in filter on hayward above ground pool.
I had similar situation.try removing winterizing plug,wrap with teflon tape, make sure no debris on threads. This worked for me. Tony
Apr 28, 2009 | Pool & Spa
Drum wont empty...have checked pump, seems to be working becasue some water is being pumped out..have checked filetr to pump and removed a couple of small buttons..outlet hose seems fine because initial...
It obviously is related to the pump and outlet hoses.
If it is a tap in waste then check for obstruction there,
Remove drain hose completely and run water though it to make sure it is fully clear.
Check inside the pump itself for any obstruction , if you are satisfied that every thing is o/k, then as a last resort, fit new pump.
Plz leave feedback for this solution.
Thanks.
Dec 14, 2008 | Hotpoint WMA35 Front Load Washer
Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
Feb 16, 2008 | GE WSXH208A Front Load Washer
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
