Question about Garden
How to remove the recoil starter on a McCulloch 2827 Weed Eater?
    President:
  • 1,545 Answers
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the bottom of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or something so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place. Reassemble and you are done. Disassembly requires Torx head drivers ranging from T-15 to T-25
Posted on Oct 05, 2010
HOW TO FIX BROKEN STARTER PULL ROPE ON TB65SS WEED EATER?
You need to remove/disassemble the recoil starter assembly to replace the rope. Be carefull the spring does not get away from you if you do take iot apart.
Sep 21, 2014 | Garden
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
McCulloch Chainsaw Gear Drive Sprocket stripped
Ken's Repair Have 9 totes of parts for McCulloch saw Weed eater Modal # and Serial # Please
Feb 24, 2014 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Repair weed eater
just apply some oil to the mech.
Jun 05, 2013 | Poulan Garden
Weed eater featherlight XT260 rope pully
Your recoil could be messed up if you cant pull the rope out or if its just too hard to pull out you could have it too tight.
Jul 29, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
How to rewind a 223l weed eater
There are videos on youtube showing this procedure, just search threading starter recoil
Jun 03, 2011 | Husqvarna 28cc Gas Line Trimmer
After pulling the starter coil, it will not be pulled back into the machine or better said, it will not coil for another attempt at starting.
Sounds as either the recoil spring located under the the recoil housing has either broken or the plastic housing that holds the spring end has broken. you will need to remove the recoil housing to determine the problem. To remove:
1. Remove the drive tube by removing the clamp around the front of the housing and gently pull the drive tube from the engine.
2. Remove the torx or slotted screws holding the recoil assembly on
3. Remove the star washer with a flat screwdriver and gently lift the recoil from the housing.
The spring will be directly. You should be able to see the problem at that point.
Sep 27, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Replacing starter rope on bolen 150 weed eater how do u do it
take back apart and try to pull freely and if still hard you need to replace
Aug 02, 2009 | Garden
Replace pull cord Big Wheeled weed EaterString
First, remove the recoil assembly but dont disassemble!
You'll need about 3 1/2 ft. of the same size rope. Tie a knot into one end of the rope. While holding the pulley in place observe the direction the pulley moves when rope is pulled. Release pulley and cut and remove old rope. Continue winding pulley in direction rope would pull it. Do no wind too tight. Line up holes in recoil housing and pulley then push rope through pulley and out housing. Tie on handle and install recall in reverse order.
Jul 02, 2009 | Garden
Garden Logo
135 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
