Question about Bowflex Treadclimber
I have bowflex treadclimber tc5000, trouble is that when in use for climbing the right treadle moves off to the far right hitting side post on the way down. But it lines itself back up on the way up. I don't use it often now because I do not want to further damage it! PLEASE HELP!
This is a common issue caused by a frequent assembly problem, made worse by the tools sent along with the TC for
assembly. To fix it, you need the following:
1. A GOOD 5/8" wrench (not the piece of junk that came with the TC).
2. A Phillips screwdriver at least 3" long.
3. Two books at least 1" thick.
4. One book about 3/8": thick, or two magazines
5. A vacuum cleaner with a hose.
6. The Treadclimber Manual. If you don't have it, get it online at the company's web-site.
Lock the treadles (see manual) such that the TC is just a treadmill.
Turn off the TC, unplug it, and remove the power cord.
Leaning the TC first left, then right, put the 1" books about 2/3 of the way towards the back under each side. This will left the rear of the machine slightly off the ground, making the following steps much easier.
Now use the Phillips screwdriver to remove three screws on each of the two rear-most plastic covers at the base of the machine. Remove the covers. Put the screws in the covers so you don't lose them. Note that the top screw is recessed deeply into a hole in the cover!
Removing the side covers has exposed 4 more Phillips screws that hold the back plastic cover in place. Remove them, and the cover will slip off (thanks to those two big books).
Everything is dusty dirty. Use the vacuum cleaner to clean it up. You'll thank me later when you don't sneeze your brains out.
Now, behind where the back plastic cover was, and across the back of the machine, are four big bolt-heads. These are the bolts that hold the tread assembly to the base of the machine. They're probably loose. If they're not loose already, use that wrench to loosen them a bit. Either way, things are out of whack.
Go around to the front of the machine. Use the small book or the magazines to wedge the right treadle away from the upright such that the treadles are evenly spaced between the two. Don't over-do it and reverse the problem! (This is a lot easier than yelling at your spouse or significant other to "hold it, hold it" while you complete the next step.) What you want is the two treadles nicely spaced between the front uprights. Trust me, the right treadle will hold that spacer.
Go back to the rear of the machine. Using the 5/8" wrench, tighten the four bolds VERY tight. Use some muscle. The fact that they were loose was the cause of the issue.
Now go to the front. Pull out the book/magazines that you were using as a spacer between the right treadle and the upright. Do the treadles look like they're now evenly spaced between the uprights? If so, pat yourself on the back. If not, then loosen the bolts and try again, adjusting the thickness of the front "spacer" as needed.
Put the rear cover back on. Don't over-do the tightness of the screws on this (or the other) cover(s)!
Put the left and right covers back on. Take care with these, they're a bit delicate, especially the top screws. If the little rubber posts fall out of the top screws, finesse them back in.
Don't forget to re-calibrate the machine (per that manual) after you finish.
You'll now discover in most cases that a lot of issues with uneven action are now cured. Any rub marks on the right upright can be removed with the same silicone spray that is recommended for the belts.
Enjoy.
Posted on Oct 25, 2010
I'm having issues with the treadles knocking together on my Bowflex treadclimber tc5000. Is there any solutions?
If you wish to get some details about treadmill maintenance ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 30, 2017 | Bowflex Exercise & Fitness
Treadles on tc5000 wobble and rub
You have to realign treadles ,take the back cover out and at the base of your unit you'll see two slides , couple of screws and yellow bushings if bushings are still in a good shape you can align treadles , if they're broken or worn out you have to replace them , I think there are 8 of them total ,they're called IGUS bushing
Good luck
Jan 05, 2014 | Bowflex Tc5000 Climber Treadclimber...
Treadles only go uo and down about 3 inches. Hard to move them
These are fairly complex machines...call foe service 877-805-1030
Jan 03, 2014 | Bowflex TreadClimber TC5000
We canNOT get the belt on the new treadclimber - there's no give and it's just not going
Can you describe your machine type (TC5000, for example) and what you've done to try and reposition the belt? Also which belt are you referring to? The treadle belt or the motor belt? I just went through a complete deck/walking belt replacement, and it's not for the faint of heart. Needed to dismantle almost 85% of the machine.
Aug 28, 2010 | Bowflex Treadclimber
One treadle is rubbung on the upright
The rear bolts are loose. I had the same problem and found the four 3/8" bolts loose. You need to take the rear side covers off first then the rear cover to get to the bolts.
May 15, 2010 | Exercise & Fitness
Where can I get this machine serviced? The gate feels uneven. The left pad almost seems to be hitting ground before the right pad completes its stride.
hello. call bowflex directly and ask Call (800) 667-1689. They probably have service centers located around the world. Joe
Mar 01, 2010 | Bowflex Treadclimber TC5300
Bowflex treadclimber 5000
Napa 8300 silicone is recommended. Apply under belts from front to back one fluid spray and also in bearing areas. Squeaking can also be caused by the center of the treadles rubbing to hard. If this is the case they need to be adjusted.
May 29, 2009 | Bowflex Treadclimber TC5300
My bowflex tc5000 will not calibrate
Check the speed sensor and make sure it is no farther than a credit card away from the drive pully. Unplug unit Located...remove left and right rear covers and back cover. 3 screws in each and 4 screws in back. Follow 2 black wires up to drive belt pulley under back of left treadle. slide sensor in with cc between it and the pully. Recalibrate
Dec 07, 2008 | Bowflex Treadclimber TC5300
Bowflex Treadclimber Logo
923 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
