Question about Kenmore 61627 1000 Watts Microwave Oven
The microwave keyboard operates and the turntable turns but does not heat the food or drink placed inside the microwave. The circuit board was replaced last January and seems to operate fine. The unit is only 1 1/2 years old.
Check the safety switch for complete door closure.
Posted on Oct 01, 2010
Zanussi microwave model number znf21x product number 947640691
Possible bad mag or bad connections at mag or capacitor. If the turntable is turning the control circuits are working. Will be problem in High Voltage section. Is it making any kind of grumbling sounds or any bad smell??? If so Probably bad magnetron.
Sep 27, 2017 | Zanussi Microwave Ovens
My microwave turntable stopped turning but the microwave still heats up and works, otherwise.
You didn't say what model microwave you have, but most that I have seen have two separate circuits inside. One operates the magnetron (which makes the microwaves) and the other operates the other things like the turntable or the inside light etc.. It is quite possible that you have a problem in that second circuit. This allows the heating without the turning. To fix this type of problem, if indeed that is the case, requires some skillful trouble shooting inside the microwave which I don't recommend your try unless you are a skilled technician, because of dangerous voltages. Go ahead and post the brand and model number and I can be more specific as to what action to take.
Dec 24, 2015 | Microwave Ovens
Microwave not heating food model MA795B
1 door interlock
2 diode
3 magnetron
4 heat censer
5 dry joint on relay on timer board
6 Re: Jeff
Apr 12, 2012 | Goldstar Microwave Ovens
Less then a year old, the microwave has power, spins the turntable, light inside is on, there is just no heat at all in the food or drink we put inside. Is it a fuse or something else?
may want to check the thermal fuse on the magnetron or the magnetron itself.... the magnetron and the thermal fuse is located behind the control panel ... the magnetron is what actually does the heating and there is a thermal fuse/limit usually attached to the side in case it gets to hot or shorts out... good luck to you
Jan 08, 2011 | Maytag MMV1153A Microwave Oven
THeood is not getting heated and the turntable is
the unit inside the microwave that heats called the "magnetron" has gone bad or the circuits that power the magnetron and turntable have failed. if its under warranty still, send it back to the manufacturer. if not you can call some repair shops and see how much it would be to service it, but its most likely going to be cheaper to purchace a new microwave since they are relatively cheap these days, and electronics repair people are not cheap. hope this helps
Jan 14, 2010 | Whirlpool MH6150XMS Microwave Oven
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
Does not "heat" food.
The Microwave Magnetron or power circuit break down . You need to replacement the parts .
Good luck
Sep 30, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Maytag Over the oven microwave
is the turntable working
Dec 29, 2007 | Microwave Ovens
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
Kenmore 61627 1000 Watts Microwave Oven Logo
100 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
