Question about ViewSonic VX1962wm LCD Monitor
Problem in the power plug. Initially had to wiggle power plug a bit to get power. Now I get nothing even after wiggling power plug.
  • ViewSonic Master
  • 7,733 Answers
Get another cable or try to fid your friends cable to see if it works.
Posted on Oct 01, 2010
  • earl0107 Oct 03, 2010
    Problem isn't in the cable, it is in the LCD monitor portion of the plug-in fixture. I'm thinking the internal part that includes the monitor power plug may need to be replaced but I've never tried such a task. I don't know how difficult that would be. Thanks anyway.
My Acer Aspire won't recognize the battery charger. I plug it in and nothing happens. After I unplug and re-plug it back in several times, sometimes my computer will recognize it and will start to...
Try wiggling the plug around a bit to see if you can get contact. You could also try borrowing a power supply if you know someone with the same machine to isolate the problem.
Oct 16, 2013 | Lifetime Acer Aspire 4810TZ-4011...
Power laptop fujitsu st4110
Could be a bad battery, a/c adapter or DC jack on the laptop.
Remove the battery and plug in the A/C and try to power on. If it comes on try to gently wiggle the plug where it meets the laptop. If it stays on then it's most likely a bad battery. If it shuts off when you wiggle it then the dc jack is bad. If none of these. Try gently wiggling the plug and tapping the power. If you get nothing at all it's probably the a/c adapter. If it comes on briefly then it's the dc jack
Jul 05, 2013 | Computers & Internet
Advent N270 netbook will not charge. Orange light comes on initially then goes off. Also when I wiggle the plug into the laptop the light flashes on and intermittently.
It sounds like either a bad connection on the motherboard or a broken wire in the adapter making intermittent connection.
1. With the power adapter disconnected, do you have a power light? This would indicate the adapter is good and the plug is questionable.
2. Check your power adapter output with a multi-meter.(be sure to wiggle the wires around) If the power fluctuates, replace the plug.
3. If the power is solid, replace the motherboard connector.
Nov 22, 2010 | Intel Computers & Internet
Compaq Presario A900 won't turn on, and battery won't charge (no blue light on when battery charger cord is plugged in.) Any ideas please? Thanks.
The power connector for these Compaqs are notorious for failing when they get a bit grimy. Try wiggling the connector or cleaning it or even gently squeezing with pliers.
Feb 07, 2010 | Computers & Internet
Crank no start,spark frome coil and plugs also good fuel pressure
Check to make sure your battery cables are completely clean and tightened with no wiggle room on your battery terminals
I know this sounds like a silly thing to suggest, but is a very common problem. Even a little bit of debris, calcium, rust or dirt can cause a small disconnection and cause the jeep not to start. Even the smallest bit of wiggle room on the battery cables can cause this as well.
Nov 10, 2009 | 1994 Jeep Grand Cherokee
GATEWAY FPD1500 MONITOR POWER ON BUTTON TURNS GREEN FOR A SECOND, THEN TURNS ORange! and nothing ahows on screen,, i tried plugging it to my tower, and no response from monitor. plese help!!1
check when you plug it in all the copper wires are placed correctly and if that dosnt work while it is plugged wiggle it a bit and if that doesnt work wiggle it more
Jun 13, 2009 | Sylvania CL772B 17" Flat Panel LCD Monitor
No power broadband router
Initially, pls try:
  • check the output voltage of the AC adapter with the use of a DVM. Move, slightly bend, wiggle the cord specially close to the plug;
  • check the jack if it is fixed in place. If it wiggles/moves even a bit could indicate a loose/cold solder;
  • internal partial short. Possible a reverse protection diode or the voltage regulator.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 09, 2008 | Encore Computers & Internet
MY DELL VOSTRO 1500 PROBLEMS
The DC power jack on the laptop may be worn out and needs to be replaced. Does it begin charging if you wiggle the power jack a bit?
Jul 20, 2008 | Computers & Internet
Won't turn on - lights appear for a second then nothing
Probably a poor power connection either where the AC pack goes in to the wall (probably powerbar!) or where the plug from the power pack goes into the unit. Wiggle the various connectors to see which one solves the problem. As a last resort you may have a faulty power pack (try ask a dealer or friend to test your system on their power pack).
Apr 14, 2007 | JBL CREATUREIIWHITE Computer Speakers
ViewSonic VX1962wm LCD Monitor Logo
74 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
