Question about Scotts Company Scotts Lawns Easy Hand Held Spreader
I have a Republic EZ Drop hand spreader and will want to apply Scotts Winterizer with Weed Control Plus 2 -hopefully after we get some rain. The label reccomends a 5 3/4 setting for Scott's drop spreader; my hand spreader has settings 1-5. Would the 5 setting be alright to use with the EZ Drop ?
Spinnnoz
  • 12 Answers
SOURCE: Republic EZ broadcast spreader...what number to
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Posted on Apr 02, 2011
  • 31 Answers
SOURCE: I have an EZ Spreader by Republic pull behind for
Go to this web page to get all settings......
Once there I would save the file and print it out for future use....
http://www.scotts.ca/media/media/pdf/spreader_settings.pdf
Posted on Sep 19, 2009
SOURCE: I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
Posted on Mar 21, 2010
heatman101
  • 43501 Answers
SOURCE: I have an older scotts drop spreader, called a
The best way is to just place a small amount... like 5 lb in the hopper...start with it barely open and see how far you get,,, then compute from there what you need...
The settings they give you are guesamates at best and are often set to place too much... why not??? they are selling you a product!!
heatman101
Posted on May 09, 2011
  • 10 Answers
SOURCE: I just bought a new
I am sorry that neither spreader performed as they should have. This is very concerning to us, and we would like to get more information about the spreaders, if you still have 1 the manufacture date would be most helpful to us. It sounds like you could possibly have an over-application of the product as well. If you could call us at 1-800-543-8873, we would be happy to discuss this with you. Stacey at Scotts.
Posted on Jun 08, 2011
Ez republic broadcast setting for expert gardener St Augustine Weed and feed for southern lawns
The bag should have a phone number for customer support. They would be the ones to give you the conversion rate for your spreader. How many square feet are you treating?
www.naturewestinc.com
Mar 04, 2012 | Earthway Ev - N - Spred Model 2050p Estate...
I have the AccuGreen 3000 drop spreader and I am very frustrated that it does not work. I have cleaned it thoroughly and adjusted the bolt on the bottom where the wire is also. I'm wondering if the...
-I'm sorry to hear about the problems you are experiencing with your spreader. Please give Scotts a call at 877-465-5160, and we will be happy to help you out.
Hilary @Scotts
Sep 04, 2011 | Scotts 73730 AccuGreen 3000 Deluxe Drop...
After spreading turf build. per instructions two days later 3/4 of the lawn turned brown???? this has never happened before and i've always used scott products. did i lose my lawn?
I am sorry to hear about the problems you are experiencing with your lawn. This type of damage can sometimes be minimized by watering 1/2 inch every 3 days if rain is not expected. We suggest you follow this program for the next 4 weeks if you do not receive sufficient rainfall. For more information, please give Scotts a call at 800-543-8873, and we will be happy to help.
Hilary @ Scotts
Jun 16, 2011 | Scotts Company Scotts Turf Builder Classic...
I have lost my instructions for my hand held spreader. The numbers on the side that control the outlet of whatever is in the spreader--do these indicate the number of pounds per 100 sq. ft?
Below is a list of spreader settings. You may want to call Scotts at 800-543-8873 and verify the product you are using is able to be used in a hand held spreader.
  • For fine grass seed (blue, rye, fescue) use setting 1
  • For coarser seed (tall fescue) use setting 2
  • For light fertilizer (Scotts fertilizers at a regular rate) use setting 3
  • For heavy fertilizer (Scotts fertilizers at a heavy setting) use setting 4
  • For pelletized fertilizer and ice melt products use setting 5
Hilary @Scotts
May 16, 2011 | Scotts 71133 Handgreen II Hand Held...
IS there a place that lists spreader settings for the scotts turf builder drop spreader? Are they the same as any of the other more commonly listed spreaders? I want to spread some Lilly Miller Moss Out...
If the product you are planning on applying has a spreader setting for a Scotts AccuGreen, or  specifically for the AccuGreen 3000; you can use that recommendation in your Turf Builder Classic Drop Spreader.  If they do not have a suggested spreader setting for the Accugreen, or  Accugreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
Jan 30, 2011 | Scotts Company Scotts Turf Builder Classic...
I have a scotts 200 drop spreader and am putting scotts builder turf plus 2. According to the directions on the bag i need to put it on when the grass is wet which is fine...but i get about 2 rows of my...
its a common problem 1st how log is your grass if its to long it will wet the area the granuals exit it the easyest way of applying it is to aply dry the water in but have lawn cut to a lower setting at least 3 days prior to spreading
Jul 09, 2010 | Scotts Company Scotts& Accugreeen 2000...
I have an old Jackson 36HSS-26 lawn spreader. What setting should I use for various materials? I am about to spread some Scotts Turf Builder with Plus 2 weed control.
It should say on the back of the box or give some indication as to the settings but in general you can gague it from the flow rate and or the granual size but a rough setting is about 5 to 6
Jul 12, 2010 | Jackson 24" Pulltype Lawn Spreader Model...
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Apr 29, 2010 | Scotts Company Scott'S& Lawn Pro Spreader...
I have an EZ Spreader by Republic pull behind for my lawn tractor and need to know what setting I need to use for applying Scotts weed & feed along with other applications. Where or how do I get this...
Sep 19, 2009 | Garden
Need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Jul 21, 2009 | Scotts Company Garden
Scotts Company Scotts Lawns Easy Hand Held Spreader Logo
2,357 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
lnbn1975
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
