Question about Uniden Cordless Phone
Uniden phone won't receive calls
Our work (Senior High School, distance education access) Uniden WDECT 2355 shares a line with a fax machine. When the number is called, the fax machine rings but the cordless phone doesn't. We can ring out on it without any difficulty. The problem only appeared a few days ago. Might someone have changed something on it?
  • 3808ind May 26, 2008
    Can't receive calls, can make calls.
  • 39 Answers
You need a filter.
Posted on Mar 18, 2009
How do i set up fax to automaticely receive faxes after several rings
For a phone line dedicated only to the fax machine, the process is as follows:
  1. Press Menu/Set, 0, 1.
  2. You will see the Fax Receive window
  3. Use UP and DOWN arrows to change the setting to FAX ONLY
  4. Press Menu/Set.
  5. Press STOP/EXIT
Your fax machine will now answer every incoming call.
If the fax machine is sharing the phone line with a telephone, repeat the above steps and change from FAX ONLY to FAX/TEL This option will allow you to share the line with a phone only, not an answering machine. Once in FAX/TEL mode, the fax machine will still grab every incoming FAX call, and give a special ring (slightly different than a regular telephone ring) when it's a regular incoming phone call signaling you to answer the phone. I hope this helps with your problem. Best of luck!
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
Manual for uniden wdect 2355 good luck!
Oct 11, 2009 | Lands Phones
Cannot receive faxes
What is the make and model?
Call the fax machine from a regular phone to see if it answers.
I think you have some sort of phone line problem.
Fax machine modems are good or bad, nothing in-between.
Mar 13, 2009 | Office Equipment & Supplies
Not receiving faxes
make sure your answering machine is plugged in to the "EXT" jack on fax machine, and your main line plugged into "line". try setting fax rings to 1 or 2. set your answering machine to 4. your fax should intercept the call and if it hears the fax tone, will receive the fax. if it doesn't hear the fax tone, it should forward the call to your answering m/c.
Jan 03, 2009 | Brother IntelliFax-2820 Laser Fax
Can't fax long distance now-
Do you have a DIGITAL phone service like Vonage?
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line..
Dec 17, 2008 | HP Officejet 5510 All-In-One Thermal...
When I try to fax there is a beeping sound. the report says the line is busy/noresponse
i would first reset up the machine in send and receive mode, is there dial tone. let me know what happens
Dec 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Cannot receive faxs
The majority of non receive issues are phone line problems.
3 conditions must exist for a fax to receive, the phone line voltage must be high enough, the phone line current must be high enough the the DB gain must be correct.
A fax receive should be viewed in the same way a remote controle works.
When you send a fax, you manually access the phone line when you select send, you connect to the phone line, normally via a relay. Once that physical connection is made, it can send anything. Maybe not well, but it will send.
Where as receiving is an electrical signal that activates the machine. If your phone line is not up to standard, its like haveing a remote control with weak or dead batteries and trying to turn on your TV with those weak batteries in it.
Issues, simply a bad phone cord between the machine and phone jack. Some resistance may have acrured over the years. The phone jack itself may have a poor connection.
A staticy phone line will cause a fax not to pick up. Plug a phone into that line and see if there is any noticible static.
Multiple devices plugged into the phone line with the fax machine. ETC an answering machine, credit card machine, etc can cause more of a draw on a shared line, if that is the situation, at least for a test, remove everything but the fax machine from the line and see if it receives then.
Rarely if the machine can send and not receive is the machine an issue.
Have your phone lines checked well and that sould resolve the issue. And make sure the line is not plugged into the extension or phone jack on the machine, but plugged into the line jack. That is also a common problem.
Apr 30, 2008 | Office Equipment & Supplies
Re. call waiting
Using Call Waiting
If you have Call Waiting service and a second call comes in when you are on the phone, a call waiting tone will
sound. Press [ /Flash] to accept the waiting call. There is a short pause, and then you will hear the new caller. To
return to the original caller, press [ /Flash].
Note: You must subscribe to Call Waiting service for this feature to operate. Not all features are available in all areas.
Mar 19, 2008 | Uniden Cordless Phone
My new Uniden Phone/Answer machine is loading down my fax line
I have searched the user manual and can find no help on this matter, although there are help numbers listed and I'm sure they can advise, here is the link to the main page and there is a link to a pdf manual download if you don't already have one
However, it may be that you could use a T adaptor or socket doubler on the line jack and plug both in. good luck !
Jan 03, 2008 | Uniden TRU8885-2 Cordless Phone
Uniden Cordless Phone Logo
252 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
