Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My Craftsman garage door opener opens my gargage door and the neighbors. It's a newer unit (model 139.53985dm). What is the key to getting it to work only on my garage?
  • Don Maggard Oct 01, 2010
    Is the neighbors opener also a Craftsman and is it new or old? Did your opener open his from the beginning or did this start happening? Have you seen your remote open his door? This is very unusual.
    President:
  • 3,197 Answers
Try programming your opener per the owners manual.
Posted on Oct 03, 2010
Why wont my gargage remote open the door from the outside
I had to extend the antenna wire on mine due to metal siding when I put a steel door on
Sep 13, 2014 | Sears Craftsman LiftMaster Chamberlain...
I really need your help. My Craftsman unit model number is 139.53615SR manufactured 1/92. I have a three car garage. The original two remote controls were lost and since then I've used the setting in my...
Have your neighbor bring over his remote and open or close your door with it. Then hold the smart/learn button in for 6 seconds on your opener. Then see if he can open your door. He shouldn't be able to because that procedure erases the memory in your opener. No remotes should work. You need to get that remote #53778 back and program it and then see if your neighbor can open your door. If he can open your door at any point after you have held that button in for 6 seconds you need to get a new door opener.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman keyless gargage door opener model 031D0431. We just moved in and would like directions on how to recode the keyless entry. One more question...if I recode the keyless entry, do I have...
Coding the keypad will not affect the remotes if you follow these directions.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in a four digit code and press enter.
Oct 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can a craftsman 953876 keyless entry pad garage door opener work on a liftmaster garage door opener
If both units were manufactured before April 2005 or both were manufactured after that date they should work. If one is older and the other newer than that date they will not work with each other.
Jan 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door is opening when the neighbor open theirs with remot
You say you "setup the remote and the main box but doesn't solve." I think you mean you programmed the unit but I'm not sure. Anyway try holding the smart/learn button in for 10 seconds and this will erase the memory. None of the remotes should work. Now when you are sure the neighbor will not be using their opener, program your remotes. This may be what you did but I'm not sure.
Aug 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened by neighbor
Have you seen the neighbor open your door? The reason I ask is because it is almost impossible. The most common cause of a door opening by itself is a bad wall control or the wiring leading to it. You can temporarily eliminate both possibilities by removing the wire from terminal 1 at the rear of the motor unit. Do this and ask your neighbor to bring over his remote and try it on your opener.
Jun 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do you reset your codes in the liftmaster/remotes. ours goes up and down varies times of the day,found out our neighbors remote is doing it. all new houses where we live have the same garage door...
press and hold learn button for 10 seconds and then reprogram your remotes by pressing and release learn button and then press and hold remote button. The big lightbulb on the motor will flash once.
May 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener
I posted the following answer to a similar question posed by 'dodgeya' the other day.
I'm not sure how to direct you to that thread, so am re-copying my suggestion here...
>> Do you have the option to change the electronic codes on your garage door opener system? My father-in-law had the same problem a number of years ago. He had not reset the code (equivalent to the combination on a lock) from the equivalent of 0-0-0 (which his unit shipped with). Turned out that a neighbor (or neighbour - in Canada) had the same /similar unit and when the neighbor opened 'his' door, my father-in-law's door would also open. You don't have to see the person drive by - it can be the neighbors behind you as well. You may find a solution by determining if you can change the original electronic code to a different one of your own choosing.
Hope this helps.
Jan 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman (older model)
Hope this helps.
Dec 17, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
194 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
