Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Replacing the battery in my keyless entry pad didnt help. When you change the batery do you have to reprogram? If not, is th e keypad probably defected?
    President:
  • 3,197 Answers
It is not necessary to reprogram the keypad when you replace the battery. You are right - your keypad has failed.
Posted on Oct 01, 2010
My keyless entry pad will let garage down when code is keyed in, but when code has been keyed up to let it up it will not do so.
I assume you mean that the entry keypad works when the door is open but not when the door is closed. This usually indicates that the signal strength on the entry pad is low. Try changing the battery.
Insert a small Philips screwdriver in the opening on the bottom of the battery compartment cover. Pull the cover slightly outwards then pull the cover down. The battery in the compartment is a 9V battery. Then replace the cover by inserting the lip in the top of the battery compartment and then snap it into place.
If you change the battery quickly, you shouldn't need to reprogram the opener. If a new battery doesn't solve the problem, check what may be causing signal interference when the door is down. (Consider moving the keypad to a spot closer to the door opening. I know that we have the keypads placed on the side of the door jamb on our garage doors. When the small handheld remote units start to loose their batteries, bringing the remotes to that area that often works.)
I hope this helps.
Oct 04, 2013 | Sears Craftsman LiftMaster Chamberlain...
Ladies / Gentlemen: I have a Craftsman 139.53975SRT1 Garage Door Opener. What is the correct keyless entry pad for this opener? Will a 139.53876 keyless entry pad work with this opener? Thank You! ...
The correct keypad for your opener is 139.53684. The 53876 keypad is an older technology and will not work correctly. If you program it you will find your remotes no longer work and if you reprogram your remotes the keypad will not work.
Sep 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
My lift master security plus keyless entry pad for the garage door no longer will open the garage door when I key in the four digit code. Can I reprogram the entry pad and if sohow?thank you
You can try programming it but first make sure the battery is good. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can't reprogram/operate keyless entry pad for Craftsman Model 139.53661SRT3 garage door opener.
If the following instructions don't work and you have a good battery the keypad has failed.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Apr 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do reprogram my keyless entry pad to a 1995
look in your owner manul it should tell you . or go to a dealer they will be abele to tell you
Nov 11, 2009 | 1995 Ford F350
Keyless Entry won't work when it's cold
I HAVE THE SAME PROBLEM, I BELEIVE IT IS THE WEATHER . THE ONLY WIIRELESS THAT DOES WORK IS THE CLICKER. I HAVE NOT HAD WITH THAT ONE.. U COULD TRY RE-PROGRAMING
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keyless entry pad for garage door opener
THE FREQUENCY OF THE UNITS ARE PROBABLY NOT COMPATABLE THEY CHANGED ABOUT 2 YEARS AGO.
SORRY - I THINK YOU NEED A NEW KEYPAD TO GO WITH THE NEW OPENER.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Unable to locate manual to reprogram keyless entry pads
Try: Click on Sears (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Jan 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
280 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
