Question about Scosche Industries Scosche High Performance Amplifier Car Audio Amplifier
My speakers jump even when there is no bass - Scosche Industries Scosche High Performance Amplifier Car Audio Amplifier
I have a system installed and i have mtx speakers plus mtx subwoofers i want to know how could i take the bass of the speakers because it sounds horrible when loud
if you turn the bass setting in your radio down it will take the bass out, but may take some of the bass out of the subs as well, if this occurs and you still are not satified, you either have to get a car receiver with a non fading subwoofer preout, or you could get bass blockers for all the speakers you dont want the bass in
Apr 05, 2012 | MTX Car Audio & Video
My 200hd head is not putting out the full 200 watts i have a behringer 8x10 cab and before this head used to power this cab fine now even with the volume cranked you cant even feel the bass i have...
I am not sure how you are measuring the power output to verify it is less than 200 watts. With a true RMS voltmeter you should see 28.28 volts RMS across a net speaker load of 4 ohms. If you use only one 8 ohm speaker, you will get 120 watts. If you are getting the 28 volts there is nothing wrong with the amp. You MAY have blown the speakers OR not generating much bass due to processing in an EQ. I assume you are using at least 15 inch speakers if you want to feel bass. Look up your speakers specs... you will need speakers capable of 32 Hz to feel much. With this amp your speakers should have aa total rating not less than 400 to 600 peak watts or around 300 watts RMS continuous power rating. Using a lot of high end EQ will keep the amp busy at the high end and reduce the power available at the bass end.
May 06, 2011 | Kustom Deep End 200HD 200 Watt Bass Amp...
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
Noise/No Bass in Delco Systems stereo
You have a possible fault in your wiring of the speakers, the Phases of the speakers are crossed over resulting in cancelling of the low frequency- bass frequency. Hence please reconnect the speakers front and rear with the positive/ negative to the corresponding positive and negative of the speakers.If you are unable to fix the marking of the polarity use 1.5 Volt cell to connect to the speakers , if the speaker moves up the terminal on the positve of battery is positive. reconnect and test with a good bass song for result. Helpful. Good day
Jul 05, 2010 | Car Audio & Video
I have hooked this up to a working reciever that
Fill in the blanks about the working receiver.
You mention another subwoofer, which suggests your receiver manages the bass and possibly sends most or all of it to the sub.
If it's NOT sending the bass to the speaker terminals you use to drive the AM5 that would explain it's virtually silent bass module.
If those speaker terminals on your receiver can be set to LARGE, do it. Otherwise they assume the speakers are incapable of handling bass.
Apr 02, 2010 | Bose Acoustimass 5 III System
Logitech Z-2300 subwoofer/Bass volume cannot completely shutoff
Make sure the wired remote is connected completely and if that doesn't work try putting a pillow or a pile of blankets to cover both the subwoofer driver and the air port on it and that should reduce the sound coming from it. Also if it is in a corner or on a solid floor like wood or tile i would move it to a less enclosed space with carpet or a rug. Thats all I got I hope that helps.
Feb 05, 2010 | Logitech Z-2300 Computer Speakers
I have logitech speakers for my computer. I need a new cable that goes from the bottom of the bass speaker to the two smaller speakers. A couple of the pins are broken on the plug that plugs into the bass...
logitech rarely has replacement parts. and for this model is not for the u.s. distribution so youcan not even call u.s tech support for help. try ebay or craiglist. if the connector is not proprietary you might be able to get a electronic repair shop to repin the connector.
Jul 24, 2009 | Logitech Audio Players & Recorders
Prot. light at High vol. (forget Bass CD)
You may have the speakers wired for the wrong impedance.
How many ohms per voice coil?
How many voice coils per speaker?
If the speakers are DVC, are the coils of each speaker wired in series or parallel?
Are the speakers bridged on the amp or one per channel?
Jul 06, 2008 | Lanzar VIBE266 Car Audio Amplifier
Icbm 779
If there is significantly less bass even though the speakers are moving approximately the same as before, you may have one speaker wired out of phase. Disconnect one speaker. If the bass increases, double-check your wiring.
Nov 17, 2007 | Performance Teknique ICBM-779 Car Audio...
Scosche Industries Scosche High Performance Amplifier Car Audio Amplifier Logo
117 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
