Question about Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
My Canon 28-135 mm f/3.5-5.6 EF IS USM AF lens has a problem that bugs me. The zoom is not veryh firm. When I tilt the camera with the lens down at an angle, the zoom will extend by it's weight. Is this the "O" rings wearing out? The lens is only a year old.
    Brigadier General:
  • 3,006 Answers
There's nothing you can do about this, it's not a wear issue it's just poor design or poor manufacturing tolerances and is always far more likely to occur on superzooms like yours.
Contact the Canon Service Centre in your country; they may be able to offer a repair under warranty, but it's far more likely that they'll just tell you that the lens is working within normal design parameters. If that happens your best option will be to sell the lens and consider buying another, but try it first to make sure that feels tighter. The loss you make on resale and repurchase will be less than you'd pay for any repair attempt which may not actually fix the problem anyway.
Sorry this is not the answer you hoped for but perhaps it's helped you to decide what to do next.
Posted on Oct 02, 2010
Tripod mount for canon 75-300 mm lens
The XTi (400D) needs to be attached firmly to a tripod with a tilting head to enable you to counteract this.
Jun 26, 2012 | Canon EF 75-300mm f/4-5.6 IS USM Lens
Is there a manual for a Canon EF 100-400 mm zoom lens
If you mean the L IS USM lens, then yes.
http://www.usa.canon.com/cusa/consumer/products/cameras/ef_lens_lineup/ef_100_400mm_f_4_5_5_6l_is_usm#BrochuresAndManuals
Nov 23, 2010 | Cameras
Error 99 and jerky fixation of focus between 17 and approxinately 30 mm works perfectly at zoom lengths beyond this with normal rapid fix of focus and records image normally. the error and failure to...
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
For the jerky focusing ring, you need to get the lens serviced by an authorized service center.
Aug 28, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
How to take apart Canon EF 28-135mm f/3.5-5.6 IS
Having gone over a month with no response, I assume this is no longer a problem.
Jul 02, 2010 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Autofocus Failure - stopped working
Replace the broken ribbon cable in the lens
May 23, 2010 | Canon Zoom Wide Angle-Telephoto EF...
My Canon EFS 17-85 MM is locked at the 17 MM position (although it doesn't have a "locked" feature. What is the problem?
Try taking the lens off AF mode and manually turning it and trying to focus. If that doesn't help then it sound like you have an internal fault.
Jan 11, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
New Camera
Get the Canon EF 70-300mm IS USM about $500 and EFS 17-85mm IS USM about $300. The 75-300 all of them I would not use them 4 a body cap. Camera is fine or step up to XSI.
Jun 10, 2009 | Canon Zoom Telephoto EF 75-300mm f/4.0-5.6...
Auto focus does not work on the 135mm
hi i am sagha a camera repairer from mumbai, i have gone through such problems much oftenly,in your case i think it is the internal problem with the flex board inside the lens which is multitwisted on metal plate after prolonged use becomes stiff & brittle and creates hairline cracks on the pcb which in turn breaks the tiny tracks & leads to malfunction at 135 mm.
May 26, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Canon 75-300mm USM III, was initially working fine
Try cleaning your lens contacts with a soft cloth or pencil eraser. you should see 7 pins on the camera body and lens.
Apr 29, 2009 | Canon Zoom Telephoto EF 75-300mm f/4.0-5.6...
Barrel slides
A fat rubber band tight enough to stop the barrel movement, but not so tight it restricts manual zooming is the best, extremely effective, low-tech fix for this problem - I have done it for years
Apr 20, 2008 | Canon AF EF 100-300mm f/4.5-5.6 USM Lens
Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens Logo
414 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
