Question about Linksys Wireless-N WRT150N Router
Wireless router was working now its not, now light showing wireless on the router, I have internet if i plug in derectly to the modem
  • 33 Answers
Jus Powercycle the Whole N/w
Unplug Modem and Router
Plug Modem First and then Router
Check Wired Internet to Router if that Works, wireless will be Online
Posted on Oct 01, 2010
    Scholar:
  • 88 Answers
You have to go through couple of steps from the wireless computer
1.make sure that you are connected wireless to your network 2.check the ip address of computer (in command prompt - type ipconfig - make sure it comes under the same range when it is wired) 3.if you find the right ip address try to do ping here the commands are - type it in the same w/l computer cmd window
----1>ping default gateway number (ping 192.168.x.x) *** if u find replies good else just try to unplug and restart everything
-----2>ping any web address (ping www.yahoo.com) *** if you find any 4 replies from a ip address - everything fine in your computer - its the web browser not working
----3>ping an ip address (ping 98.137.149.56) **** if you find 4 replies its a DNS issue on wireless adapter else wireless router (W/L part) need to be reconfigured
Router problem. unable to connect wirelessly
This is usually up address conflict. You will have to assign the wifi or lap top to different IP addresses. You have to refer to the modem manufacturers instructions or search on net / YouTube how to do this. It's too detailed to do it here I think.
Oct 17, 2017 | NetGear WGR614 Wireless Router
I am trying to connect a wrt150n wireless linksys router to my dsl. I am using a desktop windows 7 and laptop windows vista. Please help, I have tried everything but it just does not want to work.
unplug everything, including ethernet cables. then work in this exact order.
if you get a wireless signal and no internet, plug a computer in into the router in one of the available ports and check for internet. If no internet, unplug everything and test the modem without the router. If internet available without the router, then follow these instructions
  1. plug phone line into modem
  2. plug power into modem
  3. wait for all lights to become steady
  4. plug ethernet cable into modem
  5. plug other end of same cable into port labled "internet"
  6. wait for lights to become constant on both router and modem
  7. check your wireless device for wireless service.
if you dont get a wireless signal at all, plug your device into the rear of the router and type 192.168.1.1 in the adress bar
the password and username are both "admin" or simply leave the password blank if that doesn't work
navigate to the wireless option and turn on the wireless transmiter.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Dec 01, 2010 | Linksys Wireless-N WRT150N Router
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
Linksys router will not connect with motorola 2210 modem
Your problem may be timing.
Make sure you have all your cables connected correctly.
Do not have power to either the modem or router.
Plug in you modem and watch the lights go to work. Wait for them to settle down. Now plug in your router, again watching the lights. It should work now.
You can download Linksys' LELA program to monitor the network. Shows green lines to your computers, etc. when working and red lines when not. It will also give your status and make suggestions if you loose your connection.
Good Luck
Feb 24, 2010 | Linksys Wireless-G WRT54G Router
Router Wont COnnect To Internet
Reboot your modem, router, and computer. Power them all down (unplug the modem and router if necessary) then boot the Modem, then after a minute boot the router, then your PC and see if all is well, it should be.
Jul 24, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Netgear WGR614 internet light not coming on
Hi there.
Reset the wireless router by removing the power cord from the back of it for 30-60 seconds, then plug the power back in wait for 2 mins then try to reconnect again.
If you get no joy please post back for aditional advice.
Good luck and thanks for using FixYa!!
May 11, 2009 | NetGear WGR614 Wireless Router
Blinking amber light on modem icon
that means there is usually a problem with your modem. you know how to hook up a router, right? usually you unplug power from both devices, plug in your modem and let it load, then plug in your router. (with some isp's id will work the other way around.
May 10, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Two PC's,no access to internet upon PC connected by Adaptor.
solution 1:Reset the new password for accessing for internet.
solution 2:check with adapter.plug out and plug in the adapter(and also antenna too )
Feb 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin router
I just worked on one of these today. Try this and see if it helps.
1. Unplug your cable or DSL modem and your wireless router
2. Plug back in the cable or DSL modem and wait for the internet to successfully connect (watch the lights).
3. Plug the wireless router back in again and wait for it to connect (again, watching the lights)
If this doesn't work, make sure you have the equipment plugged-in in the right order.
cable or dsl signal goes to modem ==> modem plugs into wireless router ===> computer plugs into wireless router.
Feb 02, 2008 | Belkin (F5D7230-4) Router (587009)
Linksys Wireless-N WRT150N Router Logo
189 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
