Question about Nordic Track NordicTrack Treadmill, A2550
We just got a used nordic track A2550 and it's in a couple of parts, the track and the monitor/legs. We cannot figure out how to hook up the wires that are hanging from the bottom of the monitor/legs area (I believe it's 38 in the owner's manual but don't have it in front of me). I suspect that when the previous owners took it apart, it became disconnected from the tread area below. We are trying to get into the machine now to see where it connects. Any ideas?
  • hatchfamily Oct 01, 2010
    thanks but I have the manual (just didn't have it in front of me when posting). Anyway, I believe the connector from the wires (38) has come off the motor part on the underportion of the treadmill. I believe that comes from the factory connected, but during disassembly, it came apart here. Looking for an answer on where 38 connects. Looks like it's connected on the top of the treadmill, goes through the leg and is hanging out of the bottom. Thanks.
    President:
  • 2,777 Answers
I could explain it to you but it's so much easier with pictures. I have placed the manual online so you can view it all in it's entirety and save it to your computer if you wish..
http://dl.owneriq.net/e/ec84603f-87a7-47a0-a28f-88d137d3c09c.pdf
Posted on Oct 01, 2010
  • Tim Grayson
    Tim Grayson Oct 01, 2010
    Yes it does connect to the motor there, it should have an applicable plug that you can spot... Trying to find some pictures of this myself so I can give you better instruction, but you are correct.
    Thanks
    Tim
Nordic track a.c.t. classic elliptical belt tensioner
You have to loosen the underside bolt as well as the 10mm bolt on the side . The 10mm bolt locks the adjuster in place. The underside 16 mm bolt is the adjuster.
Dec 07, 2013 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track 3000 say I am going 4.9 mph when I push 3mph and when i push 4 it say i am doing 6 what is wrong . a couple days ago it said demo mode, how do I change it from demo mode to regular mode/
RUN the software calibration for easy diagnostic, and fix it. Go to the HOOD cover motor, and follow the steps or ready your owner manual.
God bless you
Sep 29, 2013 | Nordic Track NordicTrack Treadmill, A2550
How do we fold up the nordic track A2550
see the video attached and procede according. Happy New Year and God bless you
Dec 30, 2012 | Nordic Track NordicTrack A2550 PRO...
I just put my tread mill together Nordic Track A2550 and the belt wont move
1) test your circuit breaker home,reset
2)test the outlet for 115 vac
3)test the power cord if some wires is loose or cutting
4)reset your circuit breaker insider from your equipment
5)Eliminate any extension cord from your treadmill.
6)Be shure if the receptacle have ground cable with your divided TRSS.
sincerely.
ERNESTO CUADRA
MANAGUA,NICARAGUA. C.A.
Dec 11, 2011 | Nordic Track NordicTrack A2550 PRO...
Manual for a2550 nordic track treadmill
Please go the next web page for download free:
http://fitness.manualsonline.com
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 24, 2011 | Nordic Track NordicTrack Treadmill, A2550
Technician came out to replace the lift frame (had faulty welding) now console comes on but the belt and incline do not move, he doesn't know what is wrong
Check the upright cable for crimped or broken wires and the connections to the controller board and the console. Most units run the cable up the right side leg. If they are damaged you need to splice them back together. Hope that was it.
Oct 01, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a Nordtrack viewpoint 3000, the tv will come on and when I touch the start botton it just beeps.
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Aug 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
Hello, I have a Nordic Track 2050, and got on this
console is bad no other alternative, check ebay for part
Jul 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
How do I replace incline motor on A2550? Can't figure out how to remove plastic housing to get to motor
if you screw this retirastes some visible, now look on the underside of the treadmill, sometimes the screws are hidden. and the engine is easier because you only withdraw the two screws that attach it, to do this you turn the machine so you will not be difficult. Remember to remove the wires that go to the board before removing the engine, as you do with the sensor elevation.
Feb 19, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack Treadmill, A2550 Logo
66 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
