Question about Panasonic PT-60LCX64 Television
I get a message on screen telling me the filter needs to be checked and to call for service.
    Brigadier General:
  • 3,006 Answers
Your tv has cooling fans in common with most flat panel tv's and they draw the cooling air in through air filters. Unfortunately on your model, the filters are located inside the tv and are not user serviceable due to the amount of disassembly required. That's why your tv is telling you to get a qualified tv servicing technician to attend to it.
When the filters get blocked, the tv will overheat sooner or later and break down: a relatively cheap routine servicing matter then becomes an expensive repair.
I strongly advise against trying to clean the filter yourself as it is very easy yo ruin your tv, but if you are technically competent with servicing this kind of equipment then you can download the service manual for free from here. You'll also need a program such as WinRAR to decompress the file.
I hope that you have found my reply to be of assistance to you, please take a moment to rate my answer which has been provided at no charge to you..
Posted on Oct 01, 2010
Testimonial: "Was able to download the service manual after I downloaded WinRar. Thanks for the help."
  • Obertelli
    Obertelli Oct 01, 2010
    WinRAR is very good but you have to pay for it after a trial period. If you want a free RAR extractor then tryhttp://download.cnet.com/Free-RAR-Extrac...
How do I dismis text message engine system needs service, had it serviced 3 weeks ago
the message may be a new message telling you that something needs attention ( called a service) but not as a full oil and filter type service
take it in for a fault codes check and if nothing is found reset the ECM using a scan tool
Oct 02, 2016 | Cars & Trucks
Carrier model FCBNF030 where is the filter located in the unit?
There may not be one. Most filter messages on a thermostat go by accumilated run time. They are just a reminder and the thermostat message has to be reset. If its there it would be at the unit inlet were the return plenum connects to the unit. They dont usually have both if you have filters in the return grills you dont need them at the unit.
Jan 13, 2014 | Carrier Heating & Cooling
I have a 1998 GMC Sonoma 4.3 LV6 AT.
Cpuld be bad ignition wires, plugs. Dirty air filter. Plugged up fuel filter. Message me if intrested and I'll tell you how to check.the codes yourself using a paperclip.
Jan 01, 2014 | 1998 GMC Sonoma
Some type of error message
These problems can be created by loose contacts in power outlet, RC jack, cable, sockets. Check these thoroughly and if necessary, change the RC cables. The message you see might be something related to auto shut off activated due to poor or lack of signal. This might also be from the service provider's computer.
Aug 21, 2012 | Panasonic Viera TH-50PX80U Plasma TV
Various times in the day - screen reads service info check, what does this mean?
Nokia 6700 clasic:
Go Menu->Messaging->Message settings->Service messages and choose OFF all three stafs.
Disable= Service messages. message filter. autom. conncetion.
by <dimongrek>
Jan 26, 2011 | Nokia 6700 Classic Cell Phone
NOKIA 6700 CLASSIC CHECK INFO SERVICE
Nokia 6700 clasic:
"Check info service" If you saw this message on your phone after a reboot, then:
by <dimongrek>
Nov 28, 2010 | Nokia 6700 Classic Cell Phone
On dashboard where it shows oil life percentage, to the left it says B2. What does B2 stand for?
That is a Message Minder program built into the car. Its telling you to have the vehicle serviced. Owners manual will break it down but basically its telling you to change oil, rotate tires, inspect brakes, replace cabin air filter, check all fluid levels, tire pressures, replace Air filter. etc. Dealers can run 250.00 and up. Most can be done by yourself if you are so inclined or a local shop for less
Jun 02, 2010 | 2007 Honda Accord Sedan
Can you tell he how to send a text, I cant see anything on screen
The normal procedure for sending a text message in your phone is as follows. If this does not work, please take it to the nearest service centre before anything searious happens. Also the following instruction needs you to have your message centre settings filled as got from the service provider.
Process:
Press Navigation key (Centre) -> Select 'Messaging' -> Select 'Create Message' -> Select 'New Short Message'
I hope this could help you understand your problem better.
Have a nice day
Bye
Nov 26, 2008 | Motorola Mobility RAZR V3
E-mail login error
i log in to my email and it tells me how many email i got but when i click on it, it gives me all these login error message and i click okay button the screen gets a loading message and i wait and wait and wait but nothing happen and i just want to check my mail
Oct 12, 2008 | Yahoo Mail
Panasonic 50" LCD TV PT-50LC13
I did the following 'press and hold both the "VOLUME Down" button on the TV itself and the TV/VIDEO key on the remote control simultaneously for about 7 seconds (they say over 5 seconds in the manual)"
Will in the service screen I selected the number of hours of the lamp with the down arrows and the action buttons. Then I simply pressed and held the "down volume button" on the remote until the number of hours was 0. Then I turned the TV off, then back on and the message was gone. This worked for me.
Jun 21, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-60LCX64 Television Logo
550 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
