Question about Safe T Alert Lp Propane Gas Alarm Rv Trailer
MY SAFE T ALERT IS FLASHING GREEN WHAT WOULD THIS PROBLEM BE?
Green light flashing on first alert smoke detector
Remove the covers and give good clean with coton and meths sensors and covers and resit the alarm good luck.
Feb 06, 2017 | Home
How do I get a copy of the instruction manual?
Is Safe-T-Alert Surface Mount 12V RV CO Alarm a carbon monoxide detector?
Sep 30, 2014 | Alert Safe-T-Alert SURFACE MOUNT 12V RV CO...
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
Model A12AWU-UF7
That is an alert code. Most heaters require forced air venting, and some use a vacuum switch to test for that airflow before igniting gas flame.
May 07, 2014 | Heating & Cooling
First alert 9120b
Hi hislop_amand,
I know this is coming to you late yet I just seen your post and hope the following can still help you or others.
Kind Regards,
SD
FIRST ALERT Model: 9120 9120B
Normal Operation (AC Power)
Green LED ON; flashing Red LED once/ minute
No Audible Alarm
Normal Operation (DC Power - 9120B only)
Green LED OFF; Red LED flashes once/minute
No Audible Alarm
Mar 23, 2013 | First Alert SC9120B Smoke / CO Detector...
Our "Clean" light is flashing green continuous and
Try running a cleaning cycle with no dishes. If you have hard water, try adding a little CLR, or cleaning solution. Check the bottom of the washer for clogged bottom drains. Also check the manual if you have it. Sometimes holding down the button for almost a minute will reset the systems alert for cleaning. Unplug and let it set for a few minutes. Good luck
Feb 21, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
2007 Honda CRV "D" flashing and "N" solid red...
just a system awareness alert by flashing the light! you will be fine. good luck
Sep 18, 2009 | 2003 Honda CR-V
Mands lights
I had the same problem on my 00 disco II, i change the crank position sensor and problem solve....
Jul 10, 2009 | 1999 Land Rover Discovery
How to clear message symbol and flashing green alert
A: The envelope means that you have received unanswered calls in the Caller ID Call Log. To remove the Envelope press the "CALLER" button to review the missed call telephone numbers by scrolling with the ARROW buttons
May 11, 2009 | Lands Phones
Safe T Alert Lp Propane Gas Alarm Rv  Trailer Logo
174 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
