Question about Samsung Digimax D53 Digital Camera
La fotos salen blancas como nubladas con nubes
3 Suggested Answers
rajdeepdutta
  • 2517 Answers
SOURCE: Cuando tiro una foto de dia la imagen sale muy
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Posted on Feb 14, 2011
SOURCE: Hola, las fotos con la
¿En que modo estas sacando las fotos?´¿Est? en autom?tico? Podr?a ser que el sensor de luz est? dejando pasar demasiada luz y quema las fotos. Puedes intentar de resetear la configuracion a la de f?brica, esto generalmente est? disponible a trav?s del men?. Si esto no lo soluciona probablemente haya un problema con la camara.
Posted on Feb 28, 2011
How can i repair speaker problem of j20i
hola tengo un celular Sony Ericsson w 395. En este momento se apago, dejo de funcionar. La pantalla se puso blanca y no deja ver nada, algunas veces timbra y se puede usar, pero ya no da mas se bloqueo totalmente. Como puedo recuperar tada la informacion? del telefono, como fotos y mensajes?
Nov 06, 2014 | Sony Ericsson Cell Phones
Hola, las fotos con la luz del dia se ven bien en la pantalla, pero cuando la saco, me queda blanca, queria saber que es lo que anda mal o tengo mal en la configuracion.
Feb 28, 2011 | Samsung Digimax S730 Digital Camera
Como imprimir una foto
Ver la foto, mantenga el dedo hacia abajo hasta la opción de guardar que aparece.Guardar la foto. Salga de la aplicación, e ir a sus fotos. Buscar la foto que acaba dedescargar y enviar por correo electrónico a ti mismo. Ir a la computadora de tu casa (ocualquier computadora con una impresora), abra su correo electrónico, e imprimir la foto.
Feb 28, 2011 | Facebook Apps
Como puedo programar un control de remplaso para tv2?
Hola mi nombre es Kimberly Ecobar con DISH Network. Tengo enetendido que necesita programar su control de remplaso con su T.V 2. Para programar el control tiene que hacerlo desde la T.V numero1, cuando usted se encuentre alli tiene que entrar a la pantalla System Info. Esto se puede hacer oprimiendo el boton de Menu 2 veces en el control #1 o tambien oprimiendo el boton System Info enfrente del recibidor, Una vez se encuentre dentro de la pantalla System Info hacia la parte de abajo tendra algo que dice Primary Remote Address y Secondary Remote Address a la par de esto una cajita blanca que contiene un numero adentro. El procedimeinto a programar el control es el siguiente: oprima el boton de SAT localisado en la parte de arriba hasta que los demas botones se iluminen en rojo una vez esto suceda ingrese un numero ente 1-15 (pero diferente al que se encuentra dentro de la caja blanca a la par de Secondary Remote address) y despues el signo de numero (#) seguido por el boton de record. El numero dentro de la caja blanca para secondary remote address debe de cambiar al numero que usted elijio si esto no secede asi intente de nuevo el procedimiento esta vez oprimiendo el boton de record 3 veces. En este link puede encontrar todo el procedimiento y mas informacion en como programar su control http://www.dishnetwork.com/SupportSection/remote-setup. Si tiene mas preguntas o necesita ayuda por favor contactenos directamente al 1800-333-DISH, gracias y espero esto le sirva de ayuda.
Feb 12, 2011 | DISH Network IR Remote Control
Descargas las fotos en computador con windows 7 y como la recargo y como se que esta tomando la foto
Install the DRIVERS for WINDOWS. Keep in mind that the OS in this drivers work in Windows 98 (including the second edition), Windows Millennium Edition (Windows Me), Windows 2000 Professional, Windows XP Professional, Windows XP Home Edition.
Additional details about format pics, charging with USB cable (page 17), and transfer pics from camera/pc (page 11) could fiind in the DS6618 Owners Manual (PDf format).
Hope helps (remember to rate this answer).
Jan 12, 2011 | Oregon Scientific DS6618 Digital Camera
La impresion de las fotos me salen con un tono magenta que predomina toda la fotografia. Le he cambiado el cabezal y sigue igual
I have a similar problem but with green tone instead. I have tried everything and still does not work. This is a very expensive printer and do want to fix it. Did you get to fix yours?
Fleur
Sep 18, 2010 | Canon i9950 InkJet Printer
LAS LUCES EXTERIORES NO ENCIENDEN
i am getting the problem in graphic card . dispaly cannot change ,and cannot change setting in display , plse give solution or solve this problem.
Feb 04, 2009 | Foxconn 865G7MF-SH Motherboard
Samsung Digimax D53 Digital Camera Logo
43 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
