Question about Siemens A65. Cellular Phone
When i turn on the phone, the phone works well. But after sometime or if i press keys it turns off automatically. battery is ok, i checked that. please tell me what to do?
    Master:
  • 473 Answers
Issue on Battery Battery Need To Be Change, On the Phone
Posted on Oct 01, 2010
My 6500s1 it turns on and turn off
Hello Dear:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 29, 2013 | Nokia Cell Phones
Nokia N 70 switch on it will automatically off after 5 or 6 second what i will do? My battery is OK. when i try to format it automatically off.
Could be a virus.. format your phone using this method... turn off your phone.. press answer call + 3 + * and turn on the phone while keep holding other 3 keys.. it will format your phone..
If the above doesnt work, reinstall phone software using nokia software updater.. download nokia software updater.. connect your phone with pc using USB cable.. it will search for any available update.. if it says you got latest version... check the option reinstall current version..
Apr 13, 2011 | Nokia N70 Cellular Phone
Hard reset of nokia n95
Here follow this....check the battery ok.....do it...Press and hold 3 keys i.e. Green, dial key, *, Star key, no. 3 , key on keypad and then press the power on/off to switch on the phone.Examine the battery backup of your phone. Remember, do not let go the 3 button i.e * + 3 + green just press and hold keys until you see a formatting word screen shown........But in N series don't release the three button until the time set shown . original system and factory setting has also done automatically.There is no guarantee coz it might not work with some phone.............................................Try and Enjoy
Aug 21, 2010 | Nokia N95 Cellular Phone
My n79 stops working after a few seconds when i turn it on and some times it shuts off and restarts, and the keys wont work only the on/off. it will charge the battery and still except calls but i cant...
your keypad is in good condition? cause sometimes the keypad is still in press. if is not try format your phone but first back-up your files. when format press * key, call key and 3 key and power key. always update your phone to the latest firmware.
*#0000# to check the firmware
Jul 11, 2010 | Nokia N79 Cellular Phone
My n70 switches off automatically
You should do a hard reset of your phone and then check your phone again. Do to hard reset, Follow the following three simple steps :
  1. Turn your phone off.
  2. Press and hold these three keys " * ", " 3 " , " call receive button ".
  3. While pressing these three keys, turn on your phone.
Dec 21, 2009 | Nokia N70 Cellular Phone
Every five seconds my phone automatically locks, and I then have to hit the unlock key > yes key. It is a pain. Anyway to delay the kicking in of the unlock key?
GO TO SETTING AND PHONE SETTING REMOVE AUTOMATIC KEYPAD LOCK TURN OFF AND PRESS OK - SOME MOBILE HAVING THIS IN DISPLAY SETTING.
Jun 10, 2009 | Cell Phones
Pls. help.!!how can i reformat my nokia 6600.?
To format your cell phone, you need to dial *#7370# and after it gets formatted then just switch off your cell phone and then when your phone gets completely switched off then press and hold the send key (green) and while holding the send key press * (star key) and then number pad key 3 (three) hold them simultaneously and switch your cell phone back on and keep holding those keys till it shows FORMATTING,,,,,,,,,,,,,,
Make sure that the battery is fully charged before proceeding.
Feb 08, 2009 | Nokia N70 Cellular Phone
My Nokia n73 turn's off automatically
check your battery if its properly / safely enclosed. try to reformat it by pressing (*)(3)(call key) upon startup..make sure your battery is full while doing reformat.
here everything will be deleted and your memory will be cleaned.
some cause would be because your phone has virus. so that made your system failed and eventually it turned off.
Jan 09, 2009 | Nokia N73 Cellular Phone
Locked cell phone keypad
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad? To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK button. You can set your phone to lock the keypad immediately, or automatically if no key is pressed after 30 seconds, 1 minute, or 5 minutes.
To unlock the keypad: Press 1-2-3 in that order."
good luck!
Apr 15, 2008 | Kyocera K10 Royale Cellular Phone
PLease help me with my Nokia 6288... Thanks!
hi there i have had that problem once, and i'v solved it.
for the heating of the battery and no lights, no display, no signal its all for the flex(ribbon) problem all i did was remove again the flex and clean the contacts sometimes it shorts i just re-solder the contacts of the flex. because some of parts that we bought is not 100% ok. just try it again maybe you'll make it.
ok
peace!
Mar 28, 2008 | Nokia 6280 Cellular Phone
Siemens A65. Cellular Phone Logo
292 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Colin Stickland
Colin Stickland
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
