Question about Arris DCT6200 DTV Receiver
Error code E 68 - Arris DCT6200 DTV Receiver
    President:
  • 2,777 Answers
The error code and the statement that the cable company can't access the box indicates that either the box has a hard fault or the communication path has been corrupted. A hard fault would require your cable company to repair or replace the box. The communication path can be corrupted by failure of splitters, connectors or cables, which doesn't "just happen" often but is a possibility. It sounds like the cable drop to your house is split prior to entering the house, therefore, I would recommend inspecting that area to determine if the exposed cable/splitter has been tampered with or damaged. If there are other cable access points in the house, then there are other splitters that should be checked. BTW, have you tried plugging the cable directly into your set to see if the set's built-in NTSC/analog cable tuner can receive any signal? This could help rule in/out connectivity issues or 6200 stb failure.
Posted on Oct 01, 2010
Testimonial: "Thanks"
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
Treadmill error code 68
f91790db-4de9-486c-b68a-34e9745503d7.gifplease download the owner manual for identify the REED switch. go www.fitness.manualsonline.com
God bless you
Jun 16, 2013 | Avanti Fitness AT380 Treadmill
Frigidaire affinity error code 68
what is the name and model of these dryer.rate these for clean solution
thanks
Jan 16, 2013 | Dryers
I have one printer lj 2420 68.0 permanant storage full error
Error 68 is simm memory problem.
68 Error / Service / Cold Reset
All printers
  1. Temporary error. Cycle power to printer
  2. Bad formatter PCB
LJ4, 4+, 4P
  1. NVRAM not initialized.
68 Memory
IIISi, 4Si, 4V
  1. Bad SIMM memory. Check and replace SIMM's
Feb 05, 2011 | HP LaserJet 2420n Printer
ERROR CODE:E~AC
Hello, did you this error? I'm getting the same one :(
Jul 14, 2009 | JVC Televison & Video
I get error code e-68
there's a possible hard drive issue on this.
try the ff:
-turn off your xbox
-remove your hdd from the xbox
-turn on the xbox while the hdd is removed
-if you're still getting the sme error code, your xbox needs to be repaired/replaced
-=hope that your xbox is still under warranty=- ^^
Jan 19, 2009 | Microsoft Xbox 360 Console
System error 1 light code E 68
error 68 means that the xbox has insufficient power to operate. make sure it is directly plugged into the wall. try removing accessories on your xbox like intercoolers and USB devices.
Aug 24, 2008 | Microsoft Xbox 360 Console
ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
May 04, 2008 | Frigidaire Affinity ATF7000E Front Load...
Arris DCT6200 DTV Receiver Logo
1,322 people viewed this question
Top Arris Televison & Video Experts
Electro Med Services...
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
