Question about Cameras
There is a bent pin in the slot where the card is inserted, so the camera reads 'no card' when switched on
    President:
  • 2,712 Answers
You can try using a fine screwdriver to gently push the pin in place. If you are unable to do this, take it to any electronics shop..I am sure they will assist you for free, unless they have to open up the camera.
Posted on May 26, 2008
Canon EOS rebel T1i says no card
There are a few possibilities, A the pins where the card inserts into the camera are damaged, or you have 2 dud cards borrow another you know works. And also insert the card that does not work and connect camera to computer and see if it connects. If nothing works its back to Mrs Canon for repairs.
Apr 20, 2014 | Canon EOS 500D / Digital Rebel T1i Digital...
I can not insert the memory card all the way into my polaroid 12.0mp digital camera what's wrong
The pins for your memory card slot inside the camera or on the memory card itself could be bent, you should be able to see this by using a flashlight to look inside the camera for bent pins.
Aug 24, 2012 | Polaroid Cameras
The cf card slot not working
Look inside the slot...are any of the pins bent?
Feb 16, 2010 | Nikon D70s Digital Camera
Having problems with camera staying on when putting memory card in camera,camera shut off and won't come back on until you remove memory card
You don't state what type of camera that you have or what type of card you're using. But I'm going to guess as this usually happens to cameras that use CF compact flash cards. The cause is usually a bent pin in the card reading slot.
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Jun 06, 2009 | Cameras
Olympus E10 pins bent on compact flash slot
That is correct. The camera should default and detect that a smartmedia card is now inserted to the camera and write the images to that card. As I stated earlier, the cards are independent of each other.
Mar 11, 2009 | Olympus Camedia E-10 Digital Camera
Canon powershot a95
Think you may have bent a card pin. Remove the card and the camera's batteries. Look in the card slot for any bent pins. If you see one, don't fret, it may be fixable. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible (one from the dollar store is fine for this). Take your time and use as much patience as you can muster. Take a breather in between if needed.
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
If there are no bent pins in the slot, then the next obvious thing to try is a different CF card.
Oct 12, 2008 | Canon PowerShot A95 Digital Camera
Canon Digital Rebel XT / EOS 350D
I had the same problem; I could insert the card but it wouldn't read. I Got a CF error message. I was going to get it fixed then I realised that the bent pin was touching the adjacent pin. So I intentionally broke-off the damaged pin... an now it works perfectly! Many of the pins on CF cards don't appear to function.
Obviously, only do this if the pins are touching and you can't bent the pin back straight. You could make thing worse by rummaging aroung the CF slot, but as I was going to send it away anyway, at some considerable cost, I had nothing to lose.
Sep 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Not working
Try a different memory card. Some of these cameras may not support large sizes. Try a smaller card such as a 512 or a 128.
Aug 08, 2008 | Canon PowerShot A80 Digital Camera
No memory card
Did you check the slot to see if any of the pins are bent?
Jan 25, 2008 | Canon PowerShot A80 Digital Camera
Casio Exilim won't turn on when memory card is inserted
It sound like a bent pin issue. Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck !
Aug 04, 2007 | Casio Exilim EX-Z57 Digital Camera
Cameras Logo
57 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
