Question about Dryers
My siemens 750 extraklasse tumble dryer keeps asking me to empty the filter when the door filter is already clean.
    Problem Solver:
  • 10 Answers
THE FILTER YOU HAVE IN YOUR DRYER IS PROBABLY TOO FINE
TRY A NEW ONE WITH HIGHER MICRON VALUE
Posted on Oct 01, 2010
Siemens iq 750 keeps stopping after 3/4 mins of drying
Is your water jacket empty? Could be something simple like that.
Aug 07, 2016 | Siemens Dryers
The tumble dryer bip and flash "empty water" even if no water. I have cleaned every filter (2 inside the big filter at the bottom of the tumble dryer) but still have the trouble
I want to first make sure that your dryer is serviced up. so i want you to do these steps.
Most of the problems will be resolved doing these......
As clothes are tumble dried, they drop fibres. Most of this fluff is trapped by the lint filter and this needs to be checked and cleaned regularly. Lint also builds up in the vent pipe and around the electric motor in the rear of the dryer.
1.clean lint filter
Wait until the dryer cools, open the door and lift out the lint filter.
Gently brush off lint using your fingers.
On many models, the filter may also be washed. Check your manual for instructions.
If the filter is damaged in any way, you should replace it.
2.Vacuum area where lint filter sits:
The area where the lint filter sits should be vacuumed .
Remove the lint filter, and use a narrow vacuum nozzle to remove dust and lint from the fitting.
3.Clean inside the tumble dryer:
1. Make sure the dryer is cool, switch it off and unplug it.
2. Unscrew the retaining screws on the back panel, and lift it off. Vacuum the blower area.
3. Also vacuum around the vent pipe connection.
4. Replace the back panel and refit all the screws.
4.Check tumble dryer vent hose:
8d2299a.jpgWait for the dryer to cool. Unplug the vent hose and inspect its entire length for snags in the pipe.
Make sure the vent is not obstructed on the outside wall, and fit a flap or screen to keep out small animals.
If your vent pipe is punctured or damaged, you should replace it.
To avoid dryer problems,
Make sure the dryer is level and does not rock, and consult the manufacturer's instructions for the maximum weight of clothing to dry at one time. Also, make sure clothes have been spun-dry before putting them into the dryer.
This is just initial help,
Post your comments about how things turned up, Ill be giving suggestions based on your reply........
Thanx for using fixya,
Cheers.
Sep 27, 2008 | LG Dryers
Clean filter
If this is a condenser dryer, it could be the condenser unit that needs cleaning
Dec 21, 2013 | Siemens Dryers
Hi i have a two day old beko dcu 7230 tumble dryer the water tank and clean filter light keeps coming on even though they are clean and empty is my product faulty.
not too many dryers w water tank, but the air filter light maybe due to a lack of air movement. If you have replaced an old machine, then your problem may be with the existing exhaust and duct work, you'll need to clean them out thoroughly to know. You may have to go outside or up on the roof as sometimes these also have trap doors that become stuck.
Nov 09, 2013 | Dryers
My Hotpoint condenser tumble dryer TCD980 won't dry.
hi ime not sure but some dryers have a small tank inside at bottom with a float maybe float is stuck or if it has a pump maybe not working will have one if water tank is at top of dryer
Feb 05, 2013 | Hotpoint Dryers
It keeps tripping the fuse. Have tried cleaning the filters - well, have cleaned the filters that immediately accessible, I assume those are the only ones. Changed fuse in plug, too, but that didn't make...
hello , the fuse will blow because theres a dead short in the dishwasher. 1 check the element with a multimeter this may have shorted to ground also there a possibility that the motor may have a short.then check the circuit board for any burn't parts thanks
regards
shaun
Dec 04, 2010 | Siemens 24 in. SE25A266 ExtraKlasse...
Dryer does not start after selecting a program
How old is the unit?
This was my experience...
http://www.fixya.com/ThreadAsker.aspx?thid=1179929#
Feb 09, 2010 | Siemens Dryers
Dryers Logo
532 people viewed this question
Top Dryers Experts
