Question about Maytag Washing Machines
Hi, our maytag washer la608 is leaking so we want to replace it,what size is the tub in cubic ?
  • 90 Answers
SOURCE: maytag atlantis leaking in the tub
replace water valve
Posted on Jan 06, 2008
SOURCE: maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Posted on May 25, 2009
  • 7 Answers
SOURCE: What is Cubic Ft Capacity of Washer?
It's in the model number, and it's 4.4 cft. Which is one of the largest capacity washers available.
Posted on May 27, 2009
dburns60
  • 410 Answers
SOURCE: what is the cubic size of my maytag neptune MAH 1
You can find the literature at this Maytag website if you have the correct model number.
Have a great day.
http://www.maytag.com/support/manuals_literature.jsp
Posted on Jul 05, 2009
erpaalai
  • 999 Answers
SOURCE: Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Posted on Aug 10, 2009
Cubic feet for maytag model number washer sav571eeww
washing machines are rated in pounds of wash and not cubic ft
it is rated as either 4lb, 5lb, 5.5 lb 6 lb 7 lb 7.5lb
the size will be on the same decal as the model number and power details
Jan 22, 2016 | Maytag Washing Machines
How do I find out the cubic feet for Maytag washer model A412?
Calculate it yourself: Place a straight edge across the top of the unit. Measure the height from the bottom of the tub to the bottom of the straight edge. Then measure the width of the inside center of the tub and take half that number. Then use the formula below to calculate it. For example. Height 30 inches, Width 28 inches (half of 28 = 14).
V = (3.1416 x (14 x 14) x 30)/1728
= (3.1416 x 196 x 30)/1728
= 18498.48/1728
= 10.70 cubic feet.
Mar 02, 2015 | Maytag Washing Machines
Maytag washer leaking water into tub when idle
A intake water valve is leaking and will need replacing.
Dec 30, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Sudsy water is leaking from the machine
Hello there and thank you for choosing fixya
The tub seal is the most common thing that causes Maytag washers to leak. This is unfortunate because the tub seal is an expensive repair job and not one I would suggest doing yourself. I say this because it is complicated and requires special tools to perform this job. To check if the tub seal is bad, first remove the front panel by removing the two screws from the bottom of the front panel. If you have a newer model, prize the bottom clips with a screwdriver. Then pull the bottom of the panel until the top clips release. Then start the washer and watch for a leak around transmission where it goes through the tub. If it does leak then the tub seal is bad and needs replacing. If you have the tool or willing to buy it click here for instructions on how to replace the tub seal. If the tub seal doesn't, leak you probably found the leak while performing this test.
Mar 07, 2011 | Maytag MAH6700AWW Neptune Front-Load...
What is the cubic size please is it. 4.0 of the 42832 it does not say anywhere in the book or on the machine or online.
To find the cubic volume, get a tape measure or yardstick. Measure from the back of the tub to thee front lip, note the inches. Then measure the diameter of the tub, top to bottom of door should be close.
Multiply the 2 measurements. Divide the product by 144. the result will give you cubic feet.
EXAMPLE: back to front of tub 30 inches X 20 inches diameter of tub = 4.16 cubic feet of space..
Jan 11, 2011 | Kenmore 42822 Front Load Washer
Size
This is approximately a 3.2- 3.3 cubic foot tub it is about 6 years old and is patterned after Maytag's Magic Chef line. It was a decent unit. They are most prone to loud brake squeak at the end of the spin cycle and somewhat higher than normal transmission failures. Not a bad washer though.
Jun 13, 2010 | Maytag MAV8600 Top Load Washer
Leaking from bottom I think there is a hole in drum?
Not likely that there is a hole in the tub. The likely possibilities are a bad seal in the tub, a disconnected hose to the load size switch, or a leak in the drain hose or pump. Pull the front off and look for the leak.
Jan 02, 2010 | Maytag Atlantis MAV6451 Top Load Washer
What is the cubic size of my maytag neptune MAH 1 washer
Have a great day.
Jul 05, 2009 | Maytag Neptune Washer
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
Maytag neptune mah3000aww tub size
The answer is:
Nov 20, 2008 | Maytag Neptune Washer
Washing Machines Logo
53 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
