Question about Garden
I need mixture ration of oil and gas for a Ryobi weed eater
    Scholar:
  • 150 Answers
50:1 Don't use 2 stroke outboard motor oil
Posted on Oct 01, 2010
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
My weed eater wont turn on it keeps turning off as soon as turned on it is really frusterating sorry if i spelled that wrong
Most two stroke engines in weed eaters require a premixed fuel combination of gasoline and two cycle oil. I am assuming you have a gas model which needs a gas and oil mixture. A possible problem is the choke is turned on, and once it starts you need to move the choke to run. Another possible problem is the gas oil mixture is incorrect, and you may need to remix the fuel to the manufactures recommendation.
Jul 23, 2010 | Garden
My weedeater brand trimmer won't start
I believe you have the wrong GAS AND OIL MIXTURE. MOST WEED EATERS are a Ration of 90:1 or even less 75:1 For WEEDEATER I would use a 50:1 or if you choose 32:1 should work. Use a good 2-stroke oil. DO NOT USE ANY OTHER OIL> You see the more oil you use the harder it is to start. Don't forget to Pump the fuel Bulb on the side before trying to start it.About 3 x should do it. GOOD LUCK and it is and does effect me when their is death by a LOVED ONE. My prayers are with you! From Mddoc13 ( BOB)
Aug 28, 2009 | Craftsman 25cc Gas Line Trimmer
What is the fuel mixture on the ryobi cs30 weed eater?
Mine says 50:1 on the gas cap. It's a 2006 CS30. Model #RY30120.
2.6 oz of 2cycle oil to i gallon of 89 octane fuel is what i use and have no problems
Jun 30, 2009 | Ryobi Three Trimmer Combo
I have a ryobi weedeater model 764r. how do i reset the mixture screws.it won't start.
I replaced the gas line hose and the spark plug on a 2075r ryobi proffesional weed eater. Now it will not start. Thank you
Jun 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Do you use mixed gas for a ryobi weed eater??
Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
May 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi gas blower model #ry08570 need gas and oil mix
try 40 to 1 ratio it should say on the blower if not check the ratio on the bottle of 2cycle oil it will tell you how much oil to add to a gallon of gas
Jan 09, 2009 | Poulan Weed Eater Electric Blower/Vacuum...
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
