Question about Maytag MGR5750 Gas Kitchen Range
Display panel shows F1 Fault... how do I fix this
  • 1,711 Answers
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Posted on Oct 02, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    I have a electric wall oven model cwe9000 and it is showing a fault code f1. What is that and how do I fix it?
    F1 usually indicated a defect in either the keypad or the electronic control. If the error shows when the keypad is disconnected from control, the problem is usually in the control. If the error ceases with the keypad disconnected, the keypad is usually the cause.
    Apr 13, 2008 | Kitchen Ranges
    Ge geospring hot water heater fault code F1
    Copy following links before calling GE with model and serial number for local trained service technician.
    http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
    http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
    Don't buy expensive water heaters that do not have service manuals available.
    Gene
    h
    Nov 18, 2013 | Geospring Hybrid 50 Gallon Heat Pump...
    Display shows F1
    The F1 code is an error code indicating that there is a loose of wire from it position or an over flow of liquid substance in the sensor /panel reading error i.e F1
    what you need to do to fix up this problem is to unscrew the range with bass tools then clean up all form of liquid around the lens ,panel and also the wires and fix up the loose wire if any please do this with care in other to avoid more damage on it and while doing this DO NOT USE WATER or AND LIQUID substance in cleaning use only clean rag to do this service then allow it to dry up for some time then couple it back to it position with this the problem of f1 code is solve.
    Thank you and thanks for using fixay.
    Sep 10, 2010 | Dacor ER36D Stainless Steel Island Trim...
    My washer keeps shutting off and F1 shows up on the display.
    The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
    Thank you !!
    Aug 12, 2010 | Kenmore Oasis 27042 Top Load Washer
    I have a Kenmore model 665.68610891 and F1 appears from time to time on the display board. We unplug for a while and plug it back in, it works fine for a while then F1 appears again. What is F1? Is it...
    There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    The manual will tell you what F1 means.
    Nov 27, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
    Fault Code F1
    Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
    Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
    F1-6 Fault Code
    This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
    Maytag Gemini fault codes.
    Fault code Suspect area Fault code Suspect area
    F0 - 0 None
    F1 - 1 Runaway cook upper oven
    F1 - 2 Runaway cook lower oven
    F1 - 3 Runaway clean upper oven
    F1 - 4 Runaway clean lower oven
    F1 - 5 Keypad cancel upper
    F1 - 6 Keypad cancel lower
    F1 - 7 Keypad disconnected
    F1 - 8 Keypad shorted
    F1 - 9 Slave
    Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
    Clearing F1 Fault
    Hi, Dexters Dad,
    I cannot help you without the make and model of your dishwasher. Please provide this by posting a comment here. I should get a email from Fixya telling me you posted the comment. Thankyou and looking forward to helping you get rid of the F1 error code.
    Nov 23, 2007 | Dishwashers
    Bosch
    f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
    Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
    Maytag MGR5750 Gas Kitchen Range Logo
    182 people viewed this question
    Top Maytag Kitchen Ranges Experts
    vince
    gbob59
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
