Question about Epson Office Equipment & Supplies
Epson cx 2900
My epson cx2900 got a fatal error and all light is flashing epson have replaced the mainboard and the printer head but still same problem epson refuse to repair again because they told me i have use non original ink. some body help
  • ake svenjeby
    ake svenjeby May 28, 2008
    yah u right reaparation cost more than a new printer and it would be more cheap for epson to give me a new printer? btw i get it to work "printing only" if i push some button together but that more luck if i get it to work 4 button + power on maybe u know the right combination? thanks for the help
EPSON ARE ASHOLE
Posted on Jul 20, 2008
  • Epson Master
  • 691 Answers
If the error is fatal then there is NOTHING you can do at home to sort the problem out. If Epson are refusing to repair the unit because you have repeatedly used non genuine ink then you can try and take them to task on the legality of that decision (depending upon consumer law in your area) but the chances of you getting it sorted without costing a fortune are slim to none.
There is an error which shows up in the status monitor as MAINTENANCE error and this can fixed relatively easily. It's symptoms are similar. However, a fatal error is generally just that - Fatal - and there is nothing the home user can do as this generally requires parts fitting.
Your non genuine ink is almost certainly NOT to blame for the fatal error though. At worst the **** ink you use will clog nozzles and may even ruin the print head by clogging all the nozzles and causing only blank pages to be produced. BUT can you prove this to Epson in court?
My advice - bin the printer and replace it with one from a manufacturer who appears to give a damn about their products and customers as much as their fat pockets!!
Posted on May 27, 2008
Epson R1900 cartridge carrier goes lef and grinds until it stops with flashing lights
It;s general error or fatal error. Find the Adjusment Program for R1900, then Click Printer Information Check. You will find the latest fatal Error code. You can figure the actual error of your printer.
Jan 17, 2013 | Epson R1900 Printer
Unknown Printer Error EPSON 860. All three lights are flashing at the same time, and printer will not work.
Sound like you have a mainboard issue. It's time to replace this old workhorse unless you can find an old one with a good mainboard for cheap. A replacement printer is cheaper than the mainboard.
Oct 26, 2011 | Epson laser Printer EPL-6200L Laser
My r230 is having this trouble: the two red lights are blinking.
If the Ink Out light flashes, the printer is getting low on ink; if it is on solid, the printer is completely out of ink and you need to replace the cartridge; if it is flashing rapidly, the printer detected a print head unit or ink cartridge installation error. If the Paper Out light is on solid, you need to install paper in the printer; if it is flashing, the printer detected a paper jam. When both the Ink Out and Paper Out lights are on solid, the printer thinks that there is a carriage error; if both lights are flashing, there is a fatal error and the printer will need to be sent in for service Source(s): http://www.epson.com/cgi-bin/Store/suppo...
Mar 06, 2011 | Epson STYLUS R230 InkJet Photo Printer
Epson r230
Nov 02, 2009 | Office Equipment & Supplies
Is the vista window not support the cx 2900?
Check the ERpson support site to see if they have a vista driver. it is possible they dont and you may need to sell off your old prinhter and upgrade
Aug 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
All lights blinking - what do they mean?
1. The printer cartridges are either absent or bad and should replaced. 2. The cartridge housing is stuck at its parking end. 3. The cartride housing is faulty and should be replaced. Good luck
Apr 27, 2009 | Epson Stylus C84 InkJet Printer
Power and error botton blinking epson cx 2900
Could be ink cartridge no contact, or it is dirty. Or if you try to print and this printer that flag a message " end of service life......parts." . You should reset it counter using third party software. In kinda connection with ink pad.
Apr 18, 2009 | Epson Office Equipment & Supplies
Having difficulty on printing documents by using epson cx2900?
Have you changed the ink cartrage? Could simply be out of ink.
Check your last printed item. See if it is getting lighter toward the end of the document.
Feb 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson CX2900 problem
HI,
Try to reset it :
SSC Utility has the latest version SSC Utility 4.30... This time it can now reset the Epson Stylus CX2900...
Download the latest version and Install it...
Under Configuration...
Select Installed Printer (EPSON Stylus CX2900 Series)
Under Printer Model
Select EPSON Stylus CX2800...
I hope this will help you. Link
Aug 02, 2008 | Epson Stylus C84 InkJet Printer
Epson cx2900 3 in 1 printer
the problem might be the ink, change the cartridge maybe the ink dried out....
Sep 05, 2007 | Epson Stylus C84 InkJet Printer
663 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
