Question about Casio FX-115ES Scientific Calculator
I put in 1/2 how to change to decimal and s<>d does nothin
  • Casio Master
  • 7,993 Answers
Set your calculator to the general computational mode
Press [MODE][1:COMP].
Some functions may not be available in other modes (BIN, OCT)
The [S
Posted on Oct 01, 2010
  • k24674 Oct 01, 2010
    The [S<>D] key should work just fine to toggle between Fractions/Radicals to Decimals.
    You can also press [SHIFT][=] instead of just [=] to force display into a decimal format.
    Another alternative is to configure the calc to display results in decimal format.
    To do so: Press [SHIFT][MODE] to enterf (SETUP) and select [2:LineIO]
How do i enter negative fractions on my texas intruments ti-30a?
Press 2 "a b/c" 5 + 3 "a b/c" 4 + 3 +<>- "a b/c" 2 0 =
The "a b/c" key is just to the left of the 1 key, and the +<>- key is just to the right of the decimal point key.
Jul 14, 2014 | Texas Instruments TI-30XA Calculator
How do I do a negative fraction on the Texas instrument TI-30Xa
Use the +<>- key, located just to the right of the decimal point key, to change the sign of the number just entered. For example, to enter -2/3, press 2 +<>- ab/c 3
Oct 01, 2013 | Texas Instruments TI-83 Plus Calculator
How to turn a decimal into a fraction
To change a decimal to a fraction using the TI 30, insert your decimal number, then press [2nd][PRB].(the PRB button says F<>D above it for Fraction <> Decimal)
May 03, 2011 | Texas Instruments TI-30 XIIS Calculator
How do I convert from decimals to fraction with my TI-30X IIS calculator? I need the step by step process
The following examples will demonstrate how to convert decimals into fractions using the TI-30Xa and TI-30Xa Solar. Please be aware that TI-30Xa Solar School Edition calculators do not have this functionality.
Example: Convert .25 to 1/4
- Input .25, press [2nd][<--] (says F<>D above it).
** F<>D means fraction to decimal, decimal to fraction.
Example: Convert 1.38 to 1_19/50
- Input 1.38, press [2nd][<--].
Example: Convert 9.75 to 9_3/4
- Input 9.75, press [2nd]{<--].
Mar 08, 2011 | Texas Instruments TI-30XA Calculator
On ti-30xa what buttons would u use for 16 to the negative second power please help.
1 6 y^x +- 2 =
y^x is above the divide key, the +- is to the right of the decimal point.
Oct 18, 2010 | Texas Instruments TI-30XA Calculator
How would I calculate -log(6.2 x 10^-8) on my TI- 30XA
6 . 2 EE +- 8 LOG +- =
EE is the Enter Exponent key, just above the 7 key. +- is the Change Sign key, to the right of the decimal point key.
Oct 13, 2010 | Texas Instruments TI-30XA Calculator
1x10 to the power negative 5
1 EE +- 5
EE is just above the 7, +- is just to the right of the decimal point.
Sep 09, 2010 | Texas Instruments TI-30XA Calculator
Negative 1/6 *2 3/4
Pressing ( 7 / 8 ) + ( +<>- 2 / 7 ) = will produce the answer on the TI-30XA.
+<>- is the key to the right of the decimal point.
Apr 13, 2010 | Texas Instruments TI-30XA Calculator
Wont do nothin
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 06, 2010 | SanDisk Sansa e260 MP3 Player
How do i display a fraction?
Press [SHIFT][MODE][1:MathIO].
When in MathIO, you can obtain decimal results if you press [SHIFT][=] instead of just [=] to calculate.
Also, you can use the [S<=>D] key to toggle from one display format to the other ( Fraction <-> Decimals) or (Radicals<->Decimals).
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
48 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
