Question about Rheem Water Heaters
Basement was flooded when washer inlet hose burst. Approx 6 in of water in the area where the water heater stands. Complaint of no hot water, no pilot flame. Attempt to light pilot successful but pilot will not stay lit. Heater has a combustion shutoff system that possibly tripped when the burner was covered with water. How is that reset? A defective thermocouple could also be the culprit. How do you check the thermocouple? Model nbr GG30T6A
  • 760 Answers
Certain Rheem water gas water heater models feature electronic controls with a flammable vapor sensor installed on the bottom portion of the water heater unit. This sensor is designed to shut off your water heater system to prevent fires in case flammable vapors are present within the area. If your flammable vapor sensor caused your water heater to shut down, check the area immediately for leaking gas or other flammable products. Common household chemicals such as bleach can also trip the safety system as well as unsuccessful burner ignition attempts.
White Rodgers Intelli-Vent PowerVent Control Equipped Models
  1. Step 1 Turn the water heater's blower switch off and disconnect the power cord for the water heater (refer to your particular model's operation guide for the exact location of the blower switch). Disconnect the Molex connector attached to the bottom of the control pad (the left most connector with five pins).
  2. Step 2 Turn on your multi-meter and set it to read resistance or "ohms". Connect one of the multi-meter's probes to the number two pin and the other probe to the number three pin of the Molex connector (middle black wires). If the reading on your multi-meter reads below 9k or above 45k ohms, the flammable vapor sensor is faulty and in need of replacement; you cannot reset the system until this issue is resolved.
  3. Step 3 Reconnect the Molex connector to the bottom of the control pad, reconnect the water heater's power if and turn the blower switch to the "ON" position. Press both the left and right buttons on the control pad at the same time. Wait for the green light on the control pad to blink and press the following buttons in sequence: Left, Right, Left, Left, Right, Left, Right, Right (you will need to perform these actions within 30 seconds of reconnecting the power cord to the water heater in order to be successful
Posted on Oct 02, 2010
HC code shows up after washing cycle is over
HC flashes when the hot and cold inlet hoses are reversed.
Make sure inlet hoses are connected correctly.
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Aug 25, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Black slim in hot water
SOUND LIKE YOU NEED TO DRAIN AND FLUSH YOUR WATER HEATER TANK. THERE IS A HOSE BIB AT THE BOTTOM OF THE TANK. RUN A HOSE FROM IT TO A DRAIN OR OUTSIDE. SHUT OFF THE COLD WATER INLET VALVE AND OPEN THE HOSE BIB. OPEN HOT FIXTURES IN THE HOUSE.CHECK THE DRAINING WATER FOR CLARITY. IF CLEAR OPEN THE INLET VALVE AND LET IT FLUSH(YOU MAY GET MORE DISCOLORED WATER, RUN UNTIL CLEAR). SHUT HOT WATER FIXTURES, CLOSE THE HOSE BIB AND LET TANK REFILL.
Mar 30, 2013 | Water Heaters
Government safety!!! here is how it works, water heater wont stay lit idiot washing parts with gas near water heater wont blow up. its like gun laws protect everyone from idiots !!!!!!!!!!!!!!!!!!!!!!!!!!
I see you posed a complaint about government regulation of gas water heaters under Reliance electric water heater.
You should have been here at fixya for the guy yelling about his water heater not working after he painted the basement floor.
That dang government-mandated FVIR tripped and it saved a flashover.
It saved his life, and he didn't appreciate it, because he doesn't know how to read.
He thinks his world experience is all that needs to be known.
He never rose to management and never had to make long term decisions that affect other folks, and so he doesn't care about others.
Now if you didn't do your reading before-n-after buying a gas water heater, you won't know you're supposed to take apart and clean your combustion area and burner each year to prevent problems.
If you weren't aware of air intake located on bottom of water heater, then you might not know to set your water heater on bricks so you can easily clean the screen.
If you didn't read information and ask question from qualified folks before buying your water heater, you wouldn't know that Bradford White has a customer-resettable FVIR, while most other companies require you to buy parts and/or call a plumber.
If you don't read product information at Lowes, you might not be aware that new Whirlpool water heaters come with customer-resettable FVIRs.
If you don't read, then you don't know what FVIR stands for.
So let me tell you what FVIR stands for: When I was 27 in the tile business in Chicago, 1977, my brother and two helpers were laying VA tile in a basement using old black mastic. My brother stepped out. The whole basement blew up. It killed those boys dead. My brother missed it by a minute.
They were my friends.
You probably didn't read the paper that day to discover that black mastic was petroleum-based and was ignited by the water heater. Few years later the government banned use of that mastic because people were getting burned and killed all the time. Laying black mastic was like sitting in gasoline.
Those boy's families never forgot that lesson.
Maybe it's time for you to start reading and assume responsibility instead of repeating what you heard on TV.
Jan 09, 2011 | Reliance & 50gal Electric Water Heater
Leeking water from bottom
I wrote a page on leaking water heaters with resources and information:
Page lists things to check.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Also run hand over tank to find warm spot that says where leak is coming from
A rusted tank cannot be repaired.
If your tank is rusted out, it might burst open and flood the area.
Hot water inside tank is under pressure.
Turn off heat source to water heater.
Turn off water valve located above tank.
Open tub faucet on hot side and relieve pressure from tank.
You can limp along with a leaking water heater by turning it on when hot water is needed.
For example a shower uses 5-9 gallons hot water.
Turn gas water heater on for 15-20 minutes.
Turn electric on for 20-30 minutes.
To conserve resources with next heater:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Nov 15, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Amtrol wh7p
https://youtu.be/pUOBR1k3KvM- try seeing if this video answers anything. If not, there are a bunch of others about water heaters; just look around until you find one that looks similar to the one you have and watch. Sometimes, you get lucky lol
Jun 14, 2017 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
Water heaters
That's a job if the water heater is below the window. You will have to us a bucket or pail and just keep dumping it out the window unless you have some kind of pumping system. You will not be able to completely empty the tank but you will get most of the settlement out for maintenance.
Oct 07, 2008 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
Water Heaters Logo
698 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
