Question about LG D2526 Gas Dryer
My LG dryer DLG2526W flaskes the CK FILTER light, but will not start. The filter is clean. Whats up?
  • 489 Answers
The check filter light will always flash whenever you turn it on. It's just a reminder feature. Starting problem can be many things. Possible broken belt, door not closed properly or control board issue. You will require a professional LG technician to diagnose the problem.
Good luck
Posted on Oct 04, 2010
  • edbap Oct 04, 2010
    After further searching for solutions online, I followed advice: I unplugged dryer for a few minutes, plugged it back in, and its working fine. Did not have to pay a LG tech to diagnose that, saved some $.
LG Dryer - Check Filter Blinking Light is on and the filter is clean but my dryer won't come on?
The check filter light is just a reminder. Goes off once dryer starts. Dryer not working has nothing to do with that reminder. Check to see if belt is broken. When it breaks, it stops motor from working. Just take top off and tug on belt.
Dec 01, 2016 | LG Dryers
Check filter blinking on LG dryer and dryer won't start
There is a sensor at the bottom of the filter slot and it could be bad or plugged with lint. The whole service manual is here: http://www.manualslib.com/manual/974184/Lg-Dlex5101w.html?page=45#manual
It is going to show you the page with that sensor, but you can look at all the pages, I suggest page 23 for diagnostic tests.
Jul 30, 2016 | LG 7.3 cu. ft. Electric Steam Dryer, White...
The clean filter light was flashing but it stopped after I cleaned the vent but still won't heat, Is there another vent/filter in this dryer?
the blinking filter light is just a reminder, not connected to anything. goes out when you start cycle. however, if the dryer overheated then it may have blown the thermistor fuse. check out appliancepartspros.com or repairclinic.com for how to videos and parts.
May 23, 2016 | LG DLG5988 Gas Dryer
My LG DLG2526W gas dryer wont start
I had a problem like this and our fix was to reach in and turn the drum a half a turn and push the start button. it worked for us because the motor had a dead spot on motor and once moved pass that spot, it did its job. you may have a different problem but, try it.
Sep 03, 2014 | LG DLG2526W Gas Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
The check filter light keeps coming ob to my lg tromm dryer model dle2514w. I cleaned the lint filter and also cleaned the air duct in theback, what else could this be
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Jan 18, 2010 | LG DLE2514 Electric Dryer
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
Clean filter light stays on LG TD-C70045E Dryer
I had the same problem. It actually has nothing to do with the filters. If your dryer sounds like it wants to start the capacitor is blown.
Dec 07, 2008 | Zanussi TC7102W Electric Dryer
LG D2526 Gas Dryer Logo
498 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
