Question about Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher
Dishwasher - water softener not working
I have a firenzi FIDW 41 (electrolux) which is not washing prpeorly. The water softener is full of salt - but the machine fails to use any salt at all. We have probably done 20+ washes with no reduction in salt level - the water softener remains full of salt.
Help!
Paul Derlacki
  • Paul Detrlacki May 29, 2008
    not fixed yet suspect faulty seal on water sioftner
  • Anonymous Mar 17, 2014
    When putting in Salt, the tank overflows with water
  • 868 Answers
Make sure your water temperature is at least 120 degrees .Make sure your heater element is working and last of all ,Rinse Aid is the 2nd most important after water temp.
Posted on May 26, 2008
Built in water softener
really don't know have you got the manual. Normally you have to test the water ph level and then adjust the dish washer to that ph level and then fill the salt reservoir. Not sure on your model of dish washer . However you could add a water softener to the water inlet to the dish washer . Just search for
Water softener device
see
http://www.uvguard.com/hwc-home-series/
Oct 29, 2017 | Magic Chef CDB6100 Built-in Dishwasher
My miele g680 dishwasher did have a flashing intake/drain I cleaned it seemed to be working fine, then everytime I try to start it the softener light comes on with no further washing activity.
that is just an indicator that your salt is low. it will stay on until you refill the water softener with softener salt. it will not affect the dishwasher to run it without the salt. the water for your final rinse will not be softened.
Apr 06, 2012 | Miele Dishwashers
Where do i put the salt
Hello Maria,
The salt goes in the salt compartment in the base of the washing compartment. Unscrew the lid of the salt compartment (counter-clockwise), pour in salt until the compatment is full or nearly full then screw the lid back on firmly, but do not overtighten it.
If the dishwasher is new and you are using it for the first time, pour about 1 litre of cold clean water into the salt compartment before adding the salt. If you spill any salt or the water spills over the top of the salt compartment, it will wash/drain away the next time you use the washer.
The most important thing is to only use dishwasher salt. The salt is used for water-softening and only salt sold specifically for dishwashers can be used for this purpose.
The picture above is from a Bosch dishwasher. You may have another brand or model of dishwasher, but the salt compartment will still be in the base of the washing compartment and will have a cap which you unscrew as above.
Hope this helps. If you need further assistance, please let me know the brand and model number of your dishwasher.
Regards,
BElectric
Mar 14, 2011 | Dishwashers
Hi I am not sure of the model number but the salt light is on and dishes are whitish after washing how can I resolve this
Salt light means your dishwasher using water softener unit.
Salt light is on when either the salt (used for softener regeneration) is low or the water softener unit is not working correctly. First try and recharge the salt in the container usually the lid is on the base of the dishwasher. check this site for some idea. However, if there is water in the salt reservoir then you have to call the technician and get the whole softener unit regenerated.
Hope it is not all that serious. Please rate this solution if helpful otherwise post a comment.
Feb 23, 2011 | Miele 24 in. G692SCi Plus SS Free-standing...
My dishwasher says that it needs salt what sort of salt and how much?
HOW MUCH SALT DO I NEED TO ADD?
shim.gifYour machine may have a float indicator or a warning light to tell you when salt needs adding to the water softener. Often float indicators are difficult to see, and there is no accurate guide as to how much salt you need to add. Quite simply, just add granular salt to the reservoir until it won't take any more!
The softener will use the salt to replenish itself each time you wash. As an approximate guide, you should do a full top up about once a month. If your machine doesn't have a warning light, a good way to remember to check and / or top up is to do it on a regular day of the month (e.g. the first Saturday or the 15th)
CAN I USE ORDINARY TABLE SALT?
No. Table, cooking, rock and sea salts may contain additives that can actually increase water hardness. Also, the fine consistency of some of these salts mean they are likely to clog when wet. Always use granular dishwasher salt because it is very pure and is the right consistency for use in your machine.
Granular salt is the ONLY type of salt that should be used to regenerate the softener. Be aware that some varieties of 'dishwasher salt' use Dead Sea salt. This variety may contain minute insoluble organic matter that may adversely affect the resin within your softener over time. If you are in doubt about the origins of the salt, ask the retailer or manufacturer.
Sep 30, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Where do i put the salt in my hotpoint dishwasher ?
If you don't put salt in the appliance then the regeneration crystals will clump together over time and solidify. This will cause a restriction in the softener unit.
If you stopped using it and then started again you may find that the impurities caught by the crystals have simply found their way into the appliance.
You can set the softener to be at minimum setting if you are in a soft water area.
The salt isn't used to soften the water, it's used to clean the crystals in the water softener unit.
Why Do I Need to Use Salt in my Dishwasher?
Salt is needed to ensure that your dishwasher's in-built water softener gives an optimum performance. You will especially need to use dishwasher specific salt if you live in a hard water area. You can purchase one of our Aqua test strips (part number 180876) to determine the hardness of your water from our parts and accessories store or call us on 08448 225 225 .
Manually drain the floor of the machine, put in salt, and check out.
open the salt container at the bottom, and it will be full up with water, and it really will smell bad. clean it and add salt near to 1kg. then run run a prewash cycle and then check out does the salt error is coming up.if yes then more salt needs to be added.
This will help. Thanks please keep updated. please do rate the solution positively.thank you for using fixya
Mar 17, 2010 | Hotpoint 24 in. HDA2000Z Built-in...
Dishes not clean
hi friend,HOW TO GET THE BEST FROM YOUR DISHWASHER
Always follow the manufacturer's instructions and read the directions carefully on detergent, rinse aid and salt packaging.
Cleaning your machine about once a month will remove any grease and lime scale deposits which can build up on the inside of the machine. Special dishwasher cleaning detergents are available which are used when the machine is empty. These cleaners will often leave a fresh smell in the dishwasher too. If you want to have that fresh smell all the time, use a dishwasher freshener. These are usually supplied as hanging tags, which should be carefully positioned away from any moving arms. A freshener is essential if you load during the day and then run the machine at night.
WHAT ELSE CAN I DO TO GET THE MOST FROM MY DISHWASHER?
Cleaning your machine about once a month will remove any grease and lime scale deposits which can build up on the inside of the machine. Special dishwasher cleaners are available which are used when the machine is empty. These cleaners will often leave a fresh smell in the dishwasher too. If you want to have that fresh smell all the time, use a dishwasher freshener. These are usually supplied as hanging tags, which should be carefully positioned away from any moving arms. A freshener is essential if you load during the day and then run the machine at night.
LOADING
These items can be washed in a dishwasher, with the following guidelines:
Glassware - Any ordinary glassware and ovenware such as Pyrex. Do not wash lead crystal glasses unless they carry a "dishwasher safe" label.
Tableware - Most everyday crockery is safe. Bone china usually has under-glaze decoration and should be safe. Avoid antique or hand-painted and over-glaze decorated items. If in doubt, check with the manufacturer.
Cutlery - Stainless steel and silver cutlery are normally suitable for machine washing, but it pays to rinse off any acidic food before loading to prevent any corrosion and, if possible remove the cutlery immediately after the cycle, to avoid prolonged exposure in a humid atmosphere. Do not mix steel and silver cutlery in the same basket and wash bone or wooden-handled items by hand.
Plastics - Check whether they are dishwasher safe and do not place in the lower rack, where the heating element may affect the plastic during drying.
Pans - Stainless steel is ideal for dishwashers. aluminium can be washed in the machine, but may discolour during the rinsing. If in doubt, remove aluminium pans before the rinse cycle.
Always wash cast iron and wooden handled items by hand
WHY DOES MY MACHINE HAVE A WATER SOFTENER?
If the water is soft (i.e. does not contain calcium particles), the detergent will work more effectively and there will be less streaking on dishes. Hard water can also block the washer jets with lime scale and cause deposits on heating elements, which will reduce the cleaning efficiency, increase electricity costs and shorten the life of the machine. All dishwasher manufacturers (Bosch, Miele, Siemens) and detergent suppliers want you to get the best results from the machine - and soft water is one of the most important factors in achieving this. The way to ensure water remains soft is to regularly top up the reservoir with granular salt.
Three in one salt tablets do not activate the water softener.
Granular salt is the ONLY type of salt that should be used to regenerate the softener. Be aware that some varieties of ‘dishwasher salt’ use Dead Sea salt. This variety may contain minute insoluble organic matter that may adversely affect the resin within your softener over time. If you are in doubt about the origins of the salt, ask the retailer or manufacturer.
WHAT DETERGENT SHOULD I USE?
All modern dishwasher detergents are formulated to work specifically in dishwashers. On no occasion should ordinary washing up liquid be used, as it will cause excess foam, which can result in a leak. If it is accidentally used, sprinkle ordinary salt into the chamber to disperse the resulting suds. Then rinse away the excess salt before using.
There are 3 main types of dishwasher detergent - Powder, liquid or gel and tablets. Which one you choose will be down to personal preference, but most people find tablets very convenient, although using powder is usually more economical and liquids are less abrasive on more delicate items.
WHAT IS RINSE AID?
Rinse Aid is added to a special compartment in the machine and a very small amount is released during the final hot rinse cycle, to reduce the formation of water droplets on crockery etc and so ensures that the water dries away properly and evenly to avoid leaving smears.
Dual action detergent usually contains rinse aid, which is released at a different rate to the cleaning agent and so helps reduce smearing etc without the need to add separate rinse aid. Some 3-in-1 tablets contain an ingredient, which has a 'salt action', which also helps to improve cleaning, but NOTE this is not a substitute for adding salt to the water softener.
The salt action takes place in the cleaning chamber of the machine, but does not actually replenish the water softener. Research has shown that whilst 3-in-1 detergents do clean dishes effectively, their performance is improved by adding salt to the water softener reservoir.
As the performance of machines can vary, as can local water conditions, it is always best to follow your manufacturer’s advice. Some manufacturers advise that if you have unsatisfactory cleaning performance eg white powder residue, poor drying or dirty dishes, then you should return to using three separate products ie detergent, rinse aid and granular salt. Be aware that if you have not been filling the salt reservoir and relying on the salt in 3-in-1 tablets, then it may take a few cycles to re-generate the softener.
hope this helps u
please rate me..................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Dishwashers
Salt for DDW1805 Danby
I use ordinary household water softener salt crystals, not pellets, or table salt. The table salt often is not as refined as softener crystals, and can damage the dishwasher's softener in time. Also, the water softener salt comes in a large bag (around 25-50 lbs) for about $6 US.
Jul 12, 2008 | Danby DDW1805W Designer Series...
Zanussi DE 6554 Dishwasher
Wash the dishes by hand and view them again 1 hour later. If the dishes are still cloudy it's too late you have been running in hard water for years and etched the dishes. Salt only regenerates the Xeolite beads inside the DW. They collect minerals until they can no longer hold more, then the DW washes the minerals off the beads with the salt. Check if the DW is set correctly to the appropriate water hardness of your town. READ THE OWNERS MANUAL. PS> 1. You can't use regular salt. 2. Is the salt dry? Salt must be added into water so it creates solution (brine).
May 05, 2008 | Dishwashers
Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher Logo
425 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
