Question about Ovens
I have an Amana gas stove with a self clean oven, model ACS3350AB, SN 11541019CR. The oven does not light up and if it does it is done very slowly. Are there any maintenance service for Amana in Puerto Rico?
  • Ovens Master
  • 11,800 Answers
The defect is in the controller board and you can't do anything to fix it, you don't have access to replacement parts.
The only authorised repair shop in Puerto Rico is called Bonilla Refrigeration and can be found in Ponce, Calle La Guadalupe 1931 URB.
Phone number - (787)843-6004
Posted on Oct 01, 2010
My Amana self cleaning oven quit working and display but stove top still works
pull the oven part out and check the connections on top of the oven where all the controls are ,bet it has a burnt or corroded connection here between the supply for the top and the oven
Apr 20, 2012 | Amana Ovens
Cant get oven to turn on. the only thing that works is the stove top n have to light it my self. My electical screen wont turn on which controls my oven
Check and see if the stove is plugged in. I suspect your DSI module has failed.
All these stoves ain't the same nor do they even work on the same principle. I am guessing from the picture you have a DSI system. For a more precise answer always post a mdle number. Most model numbers are posted on the oven frame of the lower drawer.
Here is your DSI service Manual
Dec 21, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I inherited an older Amana Gas oven that is self
Here is an older manual with instructions on self clean and everything else. Hope it helps!
http://shop.amana.com/assets/pdfs/literature/30946503.PDF
Jan 29, 2010 | Ovens
I have a an AMANA gas stove burners work but oven doesn't
First check the book to see if you have a igniter on this stove if so it takes a moment or two to get started, if not you need to light pilot
make sure gas is getting to burner when called for by the thermostat or oven control..
Jun 11, 2009 | Ovens
Need directions for self cleaning oven
Hi Debi
Unfortunately I was unable to find the manual in my database. But still found the solution you can click on these links and refer to the instructions :
How to self clean Gas Single Oven
Directions for cleaning Fridgidaire
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks Rylee
Apr 08, 2009 | Frigidare FGB24S5DC Gas Single Oven
Smoking Oven
soundsas if you have a dirty stove, Id reccommend running through en extended cleaning cycle, it will SMOKE, that s geting rid of any food/grease trapped inside the flue and cabinet of unit
Jan 31, 2009 | Amana Ovens
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Ovens Logo
52 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
