Question about Microsoft Computers & Internet
Microsoft internet explorer is not working have a wireless system checked for solution and ot a message stating no connection problem detected for this computer i am currently using firefox with no problems but would like to use microsoft
    Scholar:
  • 88 Answers
First check the proxy on IE 1)go to tools and click internet options 2)select connections tab and click on lan setting button 3)make sure all the three check box`s are unchecked
that should work elseif you are using IE 8 then try to update or reinstall the IE 7 on your computer - do only if you able to go online on Firefox.
Posted on Oct 01, 2010
I have an Window XP 2002 operating system that is shutting down.
this has to be caused mainly due to some hardware problems or hard disk problems. try removing your bus wire the white belt you have connected with your hard disk and reconnect it again . if it doesnt work try replacing a ram for temporary to chech the problem whether its caused by ram. let me know if the problem persists.. thank u :)
Jul 13, 2010 | Microsoft Windows XP Home Edition
When i start my internet explorer i get a box that says "your last session closed abrupt do you want to return to last session" how to get rid of it?
Click "NO".
Close Internet Explorer.
Open Internet Explor, and the message should be gone.
If not:
Disconnect from the Internet (both "wired" and "wireless" connections).
Click "YES".
Reconnect to the Internet.
Nov 08, 2009 | Microsoft Windows XP Home Edition
Internet Explorer 8 External Link Problem
hi,
1.make internet explorer as a default web browser.tools - IE options - programs, there you have option.
2.run this link: http://karthik.realslimshady.googlepages.com/outlooklinks.reg
3. if it still doesn't work check it in safe mode with networking, if it works there disable securiy software once and see.
Sep 09, 2009 | Microsoft Internet Explorer 8
I have hooked it up as the instructions state but it will not find the internet, I am useing a hp laptop and am trying to go wireless, it is the vista system
No its not your windows system, try to check again your wireless router if the software firmware are installed properly in your PC. Also to configure it and connect your internet provider to the Router, which is automatically create its own Protocol Address or Obtain Address, even on Wireless connection. This is basic on Wireless Router to connect on the internet. Good luck!
Aug 04, 2009 | Linksys Wireless-N WRT150N Router
New os xp install can'tfigure out how to connect
XP will easily configure the internet system and get it working if you go to the control panel and click "Network" then "Troubleshoot".
If it does not work after that, then one of the accessories is bad or not compatible. It also makes a difference if you connect with a dial-up modem or if using an ethernet card. XP will detect a wireless signal also and configure your modem on newer laptops. Older systems may not have built-in wireless.
Mar 27, 2009 | Microsoft Internet Explorer 8
I can not go onoline with my wireless dongle but the laptop says i have a full connection but when you open the explorer the page cannot be veiwed
check your internet settings
for Internet Explorer
1. open browser, click tools menu the select "Internet Options"
2. in Internet Options select "Connections" tab
3. at Connections, click "LAN Settings"
4. at LAN settings "Automatically detect settings" should be mark check
5. click OK to save settings, close Internet Explorer Browser and open it again.
for Firefox Browser
1 open browser click "Options" menu
2. at Options, select "Advance" then select "Network" the click "Settings"
3 Connection Settings, select "Direct Connection" if your computer directly connected to Internet provider otherwise select "Auto Detect Proxy Settings" if your using a Router.
4. click OK to save changes, close youi browser and open it again.
Hope this will help you.
Nov 24, 2008 | Microsoft MN-700 Wireless Router (p5308j)
Error code 80048820
MSN Message error 80048820, unable to signin
Problems:
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
Solution-
Step#1
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet Options. From the Internet Options dialog box, go to the Connections tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN checkbox. Finally tick/check: 'Automatically detect settings'.
Step#2
- Correct the computer system's Time/Day as current (if required).
Step#3
- Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
Step#4
- Turn off the firewall. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
Reference from:
http://www.trulybangladesh.com/itnews.php
Aug 12, 2008 | Computers & Internet
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
