Exactly where can I find the drain to see if it is blocked?
    Problem Solver:
  • 10 Answers
THE GREY WASTE PIPE FROM THE BACK OF THE MACHINE LEADS TO AN OUTLET USUALLY UNDER YOUR SINK. REMOVE FROM WASTE PIPE AND BLOW, LISTEN FOR BUBBLING IF YOU DONT HEAR ANY IT IS PROBABLY BLOCKED
Posted on Oct 01, 2010
Where exactly is the spot on bike to drain the oil
EXACTLY??? Exactly??? I don't know EXACTLY. If I wanted to drain the oil, I would look on the bottom of the engine. Have you looked in that general vicinity?
Jul 19, 2013 | Motorcycles
Coolant leaking from under the engine
Where from under the engine, is it the bottom radiator hose or clamp? Theres a drain plug on the bottom of the radiator, is it tight? Look at radiator for any damage, but to find the problem you need to know exactly where the fluid is coming from. If its coming from the actual engine block, then you have a blown head gasket, or cracked block?
Jan 04, 2011 | 2002 Buick Rendezvous
Top load Maytag A882 will not drain after it has been filled.
clean the drain pipe line remove some foreign object inside the line that coz of blocking water going out,if clean but water not going out you need to replace the drain pump of your unit.lay down the unit check the small motor that connecting to drain line remove the screw and remember the exactly position of the parts before removing,after that buy a new one and return properly and carefully.,remind unplug the unit before anything to do.
Jan 01, 2011 | Maytag SAV5710 Top Load Washer
Waterleak front passenger side , blocked drain holes?
Check first where exactly the water comes from. It may come from the drain from the AC since the evaporator is located at that side. It may just be accumulating more moisture. If it is towards the engine it may be a bad water pump.
Nov 05, 2009 | 1998 Toyota Camry
Where is the drain plug exactly on a 2003 kia rio?
For the 1.6l engines:
Looking at the engine from the front end (e.g. from the right fender), the drain plug is on the left below cylinder #1.
From beneath the car, looking towards the front of the vehicle, you'll find it on the right had end of the engine block, at the back (nearest the passenger compartment. (see image below)
You'll need a 17mm wrench or socket.
The Oil filter is above it and towards the center of the block.
May 24, 2009 | 2002 Kia Rio
I have an aquarius plus, wf740. i bought in 2005. the problem , i have today is; it will not drain out.and it is displaying a code FL-05. can you help, cf
I have just fixed my washing machine with the same fault. As yours, my machine would not drain though it would wash, i changed the pump and it was exactly the same. Eventually, after much hair tearing out I took the Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} pipe exiting from the drum off and found a hankie blocking the pipe, job done!!!
Apr 13, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Bosch WLF 2260
suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
Jun 14, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
