Proyector Sony El Enciende bien, Pero Salen lineas VERTICALES es de color verde amarillo , la imagen de "entrada" Si Se transmite Pero lineas AES en contra.
  • 2318 Answers
SOURCE: Por Favor me gustaria que
Podrias proporcionar el modelo completo de tu plasma?
Cuando proporciones el modelo te indicare donde esta la falla y tambien donde comprar la parte(s) para reparar tu TV.
Posted on Sep 12, 2010
TV #1
  • 129 Answers
SOURCE: El screem del Tv
Necesitas cambiar un tablero que se llama DMD module. Cual es el modelo del TV?
Posted on Dec 18, 2010
bbl242003
  • 1637 Answers
SOURCE: Buenas noches, tengo una hitachi
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
SOURCE: tengo un plasma sanyo 50
Amigo yo tengo el mismo problema con el mismo plasma..y no encuentro solucion...Tu ya pudiste arreglarala?? Ojala pudieras decirme como lo resolviste o cualquier info al respecto...gracias.
Posted on Feb 23, 2011
SOURCE: tengo un proyector dell modelo 2300, lo compre de
yo tengo un proyector de la misma marca y modelo pero sin la
lampara si gustas te lo vendo barato o me vendes la lampara cel 01 4611886077 luis enrique
Posted on Jun 10, 2011
Mi projector es un zenith 881 pro y mi problema es ... , se me tiro el liquido de uno las pantallas y no se como en contraro ni onde buscarlo y tambien una de las pantallas que es la del medio el que manda...
bueno creo me puedan ayudar es un projector muy viejito pero muy bueno donde puedo encontrar la tarjeta de convergencia, el tubo verde de enmedio crt, y el power supplay de un zennith 881 espero me entiendan lo que busco soy de Mazatlan Sinalo es te es mi correo danitza1420@hotmail.com gracias........
Aug 13, 2011 | Zenith Pro 881 Multimedia Projector
Mi televisor no enciende solo se prende el foco rojo y parpadea en donde dice timer
bueno tengo una television pt4298hd akai el problema no enciende parpadea el foco de timer 10 o 9 veces y no enciende destape la tapa de atras y desconecte un cable rojo que tiene el nombre de screm y la television enciende pero no se mira como debiera porque se mira el color verde y el rojo pero como si le faltara el color azul mi televisor es una dlp akai de tres lentes y quisiera saber cual es el problema
May 02, 2011 | Akai PT4298HD Rear Projection Television
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
El tv no enciende, solo lo intenta, se escucha un clikeo, el modelo es kdl-32l5000
He tenido el mismo problema varias veces, la tele parece completamente muerta. Es un problema con el modo de ahorro de energía. Si la televisión no tiene señal de entrada en uno de sus canales hdmi o vga, entra en modo ahorro de energía, encendiendo la luz de stand-by. No he determinado en qué situación aparece el problema, pero creo que es cuando, estando en stand-by, se desconecta la alimentación. Para resolverlo, desconecta la televisión del enchufe, a continuación desconecta TODAS las entradas traseras de señal, audio, vídeo, hdmi, vga... todo. Espera unos segundos, enchúfala y escucharás un click. A continuación, debe encender normalmente.
Nov 23, 2010 | Sony KDL32L5000 32 in. LCD HDTV
Imac g5 linea blanca vertical en la parte derecha
éstos son algunos procedimientos que se pueden tratar de resolver este problema con la línea blanca de la pantalla. Pero, por favor tenga en cuenta: si estos 2 procedimientos no ayudan, te recomendaría tener en tu Mac en el servicio de Apple en un centro de servicio autorizado
éstos son algunos pasos que usted puede tratar de resolver el problema:
Opción # 1
-PRAM reset -
• En primer lugar, sostiene en su botón de encendido durante aproximadamente 10 segundos para hacer una parada difícil, si no se ha cumplido ya su Mac apagado.
• Una vez que tu Mac está apagado, usted tendrá que realizar lo que se denomina un restablecimiento PRAM (RAM de parámetros)
• Busque las siguientes teclas en el teclado: Comando, Opción, P y R. Es necesario mantener estos teclas simultáneamente.
• Encienda el ordenador.
• Mantenga pulsado el Comando + Opción + P-R llaves. Debe pulsar esta combinación de teclas antes de la pantalla gris.
• Ahora, presionando las teclas hasta que el equipo se reinicia y se oye el sonido de inicio por tercera vez.
• Suelta las teclas y permitir que el MacBook a poner en marcha.
Opción # 2
-Restablecer la PMU -
El administrador de energía es un circuito integrado (chip de ordenador) que suele ser en la placa lógica de su ordenador Mac.
Es responsable de la gestión de energía de la computadora. Controla la retroiluminación, giro del disco duro, el sueño y la activación, algunos aspectos de la carga, control de trackpad y algunas entradas y salidas en relación con el reposo del ordenador.
• Si el ordenador está encendido, apágalo.
• Desconecte todas las conexiones de entrar en el Mac, excepto para el cable de alimentación.
• Una vez que todas las conexiones se han desconectado, quite el cable de alimentación de la Mac.
• Espere 20 segundos.
• Vuelva a conectar el teclado, el ratón y el cable de alimentación en el equipo.
• Presione el botón de encendido para reiniciar el equipo Mac.
Espero que esto haya ayudado a resolver el problema de la línea blanca.
Recuerdos,
-Mactechtrainer
Jan 29, 2010 | Apple iMac G4 Desktop
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
La imagen no se ve .. el display tiene luz . el sonido anda bien
Hola ... Buen dia ...
He recibido el correo ...
Bueno, el problema aun existe ... he revisado las tensiones de fuente , por lo que pude ver hasta donde pude, ya que no tengo ningun manual , es solo lo que vi , todas estan presentes ... tambien revise los reguladores de tencion de la placa que esta hubicada en el medio a la derecha de la fuente . y estan bien ... para forma de ver la principal sospechosa de la falla , por que el sonido y sintonia estan bien .. la iluminacion de la pantalla tambien . y no tengo nada de nada de imagen en ninguna condicion ..
EL ofrfecimiento que me hacen seria interesante ... pero no poseo cuenta bancaria , no targeta de credito para efectuar el pago ... por eso no me asocie ... mi momento economico es duro ...
Lo que venia arreglando este ultimo tiempo son MINILABS que hacen las fotografias. pero la enorme rececion den Argentina daño mucho ese mercado .. En la T V LCD, es la primera vez que incurro ...
Quedo agradecido por la atencion y en espera de vuestro comentario ..
Apr 14, 2009 | Televison & Video
TV Konka modelo K2038U. No enciende.
Muchas televisiones tienen reguladores ,si ese regulador no esta dando lo que tiene que dar hay que cambiarlo,tambien puede haber un corto en la linea y eso esta manteniendo bajo el voltaje,hay que chequiar los filtros(capacitadores).Suerte
Sep 06, 2006 | Konka K1369U 13" TV
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
Electro Med Services...
