Question about Dell Computers & Internet
Since the time I got my dell repaired recently.(.the hard disk had to be changed and my machine is still in the guarantee period) the sound output is not as it used to be , it is very subdued n low. Please help !!
  • Dell Master
  • 27,725 Answers
Control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Posted on Oct 01, 2010
Hard Disk not found
If it fell down, you changed hard disk and still get message "Herd Disk Not Found", probably you've got a problem in your Motherboard.. Take it ro a repair technician
Hope you still have old hard disk. Check it as external disk on some other computer, maybe it's good!.
Jun 20, 2015 | Dell LATITUDE Computers & Internet
Dell Vostro 200 goes straight to analog mode/sleep, keyboard, mouse not responding; not booting
replace bios battery, reset the bios, insert required parameters after rebooting and when windows reboot change the time period for screen saver and hard disk shut down!
Aug 05, 2012 | Dell Vostro 200 PC Desktop
It says that the hard disks sysem corrupted
Hi. This is an unfortunate occurence . The actual hard disk has corrupt clusters at this time. The only recourse will be to replace the damaged hard disk. With that said, if you have recently updated your firmware, this may cause this message as well, due to a corrupt firmware update pack. If you have not recently updated your units firmware, the necessary actions are to have the damaged hard disk replaced by a certified sony repair depot. This repair may be free of charge if the unit was purchased within a six month period,but if not, you may be charged a shipping fee, if any. contact sony asap for your repair ticket.
Oct 09, 2011 | Sony Playstation 3 (PS3) Console
I have dell inspiron 1525, with windows 7, and this message appear whenever trying to login to my pc.. "Windows failed to start, a recent hardware or software change might be the cause. File:...
The hard drive may had a BAD SECTOR ( corrupt section )
try to format with normal mode,NOT quick format.
try using LLFTOOL ( hard disk low level format ) http://hddguru.com
quite bit longer to fix the bad section,but works.
akee.4shared.com
Aug 15, 2011 | Dell Inspiron 1525 Laptop
I have a western digital 500 GB external Hard disk bought 2 years ago. Nowadays, it starts arbitrarily generating clicking sounds and then at that time my computer stops recognizing this device. The...
This is indicative of the hard drives, tracking head becoming stuck or misaligned.
I would advise backing up all the data you currently need off oth disk then replacing it as it is only a matter of time become the disk becomes completely unreadable,
Feb 28, 2011 | LaCie External USB 2.0 500GB 7200 RPM 500...
Canon iPF8100 Error message E602 401b
Our Canon iPF810 recently had the error message "E602-401B" while it was still under warranty. At that time the hard drive was replaced, but it didn't solve the problem so the original hard drive was put back in and the firmware was updated and the machine worked fine for about 9 months.
We got the same message again and the machine was not under warranty so repair would be quite expensive ($1000.00 flat rate fee). After making calls to repair places, one place gave me some valuable information.
They suggested that if I could get into "Service Mode", select "System Setup" and then "Erase HDD". They said the hard drive probably needed to be defragmented. Amazingly enough, it worked! The hardest part was figuring out how to get into "Service Mode".
With the machine switchoff OFF, hold down the "sheet or roll feed button" and the "information button". Keep these pressed and switch the machine on, keeping the buttons pressed until you see an "S" in the top right-hand corner of the display, then let go of the buttons. You should now be in "Service Mode". Then go to "System Setup" and then "Erase HDD". Your machine should work after following these procedures.
It seems like the plotter stores every plot in its memory. After a period of time, the plotter's memory gets filled up and the "E602-401B" error message occurs. To prevent this from happening, periodically erase all the old plots. The procedure for doing this is as follows:
On the plotter "Main Menu" choose: "Job Management", "Stored Job", "Common Box", "Job List". Then delete each drawing/plot.
Nov 27, 2009 | Canon imagePROGRAF® iPF8100 InkJet Printer
Diskette drive 1 seek failure is shown on when the computer is turned on primary hard disk drive 1 not found secondary hard disk drive 1 not found.
Hmmmm That is strange.
If all three of these error messages started at the same time it probably means that something has seriously gone wrong with the Input Output controller(s) on your motherboard.
Have you moved house recently? Sometimes cables can fall off inside the computer when you move them although it is unlikely that your floppy and hard drive cables would both fall off.
When the computer starts go into the bios settings the button you need to press normally flashes up on the screen. Like F2 or Del or something like that. If the date and time is wrong the battery on *********** board may have gone flat. Not a big deal to change that.
Otherwise you may be stuck.
Sep 16, 2009 | Dell OptiPlex GX110 PC Desktop
Dell d810 does not power on
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 11, 2009 | Dell Latitude D810 Notebook
Inspiron laptop Battery won't charge
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Apr 06, 2009 | Dell Inspiron 9400 Notebook
Boot problem
Apr 05, 2009 | Dell Computers & Internet
Computers & Internet Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
