Question about Sony SDM-HS93 19" LCD Monitor
I am trying to attach my SDM-HS93 Sony Monitor with a Dell Dimension 4700 computer that does not support plug and play monitors. Do I need to add a new video card to my computer? What does this entail? Thanks
  • Sony Master
  • 11,800 Answers
Actually your motherboard supports just fine every monitor there is, only that the onboard video chip (915G) is very weak so your video capabilities will be limited.
So yes, the best option would be to get a decent separate video card, one like
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500143
Posted on Oct 01, 2010
Monitor light up then shut down itself
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 11, 2014 | Sony SDM HS93 19" LCD Monitor
I have a Sony SDM-HS93 (Black) 19 I turn the monitor on and it flashes on then off and on again. does this continually.. any answer for me? I have opened the back and checked capacitors and all look...
It may have bad lamp assemblies, you need the inverter tester lamp to verify. See my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
This is common problem with the 17" version also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Feb 10, 2011 | Sony SDM-HS93 19" LCD Monitor
I have a SONY SDM-HS93 LCD monitor, Maybe Monitor receiverd an electric overstress, so the screen displayed but screen disappeared after few seconds. And if I turn it off & turn it on again, it turns...
Siny LCD Monitor is so expensive. <a href="http//www.wholesaleeshop.com.au/LCD-Monitor/index.php?keywords=philips">Philips LCD Monitor</a> is good!
Nov 02, 2010 | Sony SDM-HS93 19" LCD Monitor
Hi..my sony model sdm-hs93 lcd monitor flutters for a couple of seconds right before the screen blanks out. But, if I leave the monitor on for a day in sleep mode, the next day i can hook it up to the...
I think the problem with your monitor is that, the picture board on the monitor is malfunctioning that is why it keeps going blank after a minute.
What you need to do is to replace the picture board on your LCD monitor, replacing the picture board will solve the problem, because the picture board on the monitor at the moment is bad and will need to be replace.
Replace the picture board and you will see that the problem will not repeat itself again.
Take care.
Jul 16, 2010 | Sony SDM-HS93 19" LCD Monitor
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
Sony SDM HS93 works fine, but: Monitor will not turn on with power button, if I plug in A/C cord power light goes on, monitor works. Sometimes the monitor comes on too bright, other times, too dim....
i get same..controls not working ,,sometimes menu button works and one arrow button..button "ok" button doesnt work and up arrow...brightness not working.
i get black box in upper left corner...quite diffucult to get rid of.
G
iamthehipster@yahoo.com
Feb 25, 2008 | Sony SDM HS93 19" LCD Monitor
Sony SDM-HS93 19" LCD Monitor Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
