Question about Whirlpool Dishwashers
Cycle gets stuck in wash mode. Model DUL24QXTPt087 Cost to fix? Tks. SS
  • sandytexas8 Oct 01, 2010
    Hi - Thank you -
    I am going to test a cycle again - I think that when I use the rinse only it does not stick.... would that indicate another solution?
    Thanks, Sandy
  • Whirlpool Master
  • 17,129 Answers
It is difficult to confirm the cost unless the machine is checked and problem is obserrved but I can guide you to do it yourself so that the fault can be sorted out.
Now please observe carefully the program cycle so that we can judge the fault.
On selection of the program , does the inlet water come in in free flow? if so does it cuts off? now the wash cycle will commence and run. Does it cut off during the run or during the drain. If it stops during the run then the motor or the program controller is faulty... possible disconnection of the drive.
If it stoops during the drain cycle then check the drain valve/pump or the program controller.
So the most possible fault can be the controller.
Posted on Oct 02, 2010
  • Donald DCruz
    Donald DCruz Oct 03, 2010
    Have you tried this out. please check and respond
    Brigadier General:
  • 3,513 Answers
If your dishwasher is stuck in wash cycle and isn't draining then you will have to take off all of the shields on the bottom of the unit (on the outside) then you will see the motor. Unplug the dishwasher then put your fingers in the motor and start to turn it to free up the motor, the motor is kind of like a vacuum cleaner belt, so when you hand turn the motor you're allowing the belt to slip back into its grove. Then when you're finished, then plug it back and turn the dishwasher on and it should drain.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 01, 2010
Frigdaire top loading washer # FFTW1001PW gets stuck in wash cycle. It agitates and drains but stays in wash mode. Is there a way to fix this?
possible problem program board not progressing
call in a technician for a proper diagnosis and quote
Sep 03, 2016 | Washing Machines
Doesn't complete cycle. Gets stuck at 26 mins.
quite likely the control board has begun to fail . only fix will be to get it replaced
May 14, 2016 | Fisher and Paykel 23 in. DD603H SS...
Why does my LG WD-1049C washing machine get stuck when doing a wash cycle?
first thing to check is the carbon brushes,cheapest fix too.they wear down after a time and need to be replaced,check see if they are worn out
Mar 12, 2013 | Washing Machines
Sewing Machine stuck in SS mode
It would be really helpful to know what the make and model of your machine is ....
Feb 18, 2013 | Sewing Machines
The dishwasher gets stuck in rinse/ dry mode . It should complete full cycle in about an hour, but it washes and then does not rinse/ dry and go to OFF. Please advise
not a expert but id guess with my electrical knolage that a part needs replaceing proberbly obvious but without having a wireing diagram of that exact make and model sorry but thats all i can say my advice get a pro to look at it weigh up between cost of repair and a new dishwasher if u have a warrenty use it
Oct 30, 2012 | Dishwashers
Dishwasher stuck in wash cycle
see this causes and fix it. God bless you
.Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control 10_17_2012_1_06_02_pm.jpg
Oct 16, 2012 | Whirlpool Dishwashers
For some reason my GE GBVH6260 washer cycles are getting hung up on either the wash or rinse cycle. Some days it will stay stuck in the wash cycle & some days it will stay stuck in the rinse cycle for...
Most likely its your water inlet valve..(cold side is not letting water in). Very common problem that usually manifests during rinse cycle since rinse uses always cold water.
According to your model # , part # is WH13X10023
Jul 10, 2017 | Washing Machines
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Goes into Pause mode during Delicate cycle. Model
Did you ever get this fixed? mine is doing the same thing
May 15, 2010 | Frigidaire ATF6000ES Front Load Washer
GE WJSE4150B1WW Model top load problem
It sounds like the timer must have went bad or has a loose connection, If I understand you correctly its stuck in the spin mode. and won't go to rinse or wash cycle, Is that what you are saying, If so Maybe the start button got pushed in to hard or pulled out to hard. If It don't work let me know so we can work on something else so we can get it fixed for you, Happy Holidays bear001
Dec 13, 2007 | GE WBSE3120B Top Load Washer
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
